just a minor problem.
haha i took a nasty hit from a losi 2 weeks ago
so nasty it broke an a arm on my kyosho.
here is the aftermath of practice today after replacing the a arm
the front bearing is seized up tight.
pix of the carnage.
what i would like to know
how are the a main bearings?
http://www.amainhobbies.com/product_...el-bearings-10
i might as well replace all the bearings in my truck (ill buy two kits to keep some spares and re bearing the whole truck)
i would really like some feedback on those bearings.
pix of the carnage.
Marcus, that was some hit! Why not use Answer-RC bearings and use your Team Terribles discount? Just a thought for you. See you on the 9th.
Tech Prophet
http://tkocompetitiondev.com/product...products_id=69
these are very good bearings , especially for the price!!
the bulkhead did melt (bearing was seized up tight i had to tap the pinion out of it.)
and there is some black grease mixed in as well
i didnt know panther made bearings?
dam thats a bad hit how did the guy, driving the losi hit you on the strightaway or something?
dam my guess is the guy that hit you was, a little bit to hard on the throttle hehe.
i learn that if you arent line up right at, a jump just roll it man or brakeage will happen or worse.
Your name is Marcus?? My name is Marcus. Hope that does not disturb you.
I have been using avid bearings, I must say i am not impressed. I have had 2 wheel bearings seize up a day after putting them in. Gonna try answer rc.
My smaller wheel bearings and pinion bearings are mugen and they have lasted like four gallons
avid bearings
I've not had a problem with them on my 808. I didn't know the tko bearings were cheaper though. HMMMMM.....Anyone else have bearing recomendations? Brand, type? Who makes a trully sealed rubber bearing like the mugen wheel bearings that seem to last forever, a little drag isn't an issue if you can leave them alone for longer....they free up after the qualifiers anyhow....
the best bearing i used in by front and, rear hubs are the advange bearings
not the cermianic ones the regular rubber.seal bearing, as for clutch bearings the tko high rpm ones rock.
marcus, i really like avids, you dont like those tho. if i had the money i would put tko all around but thats not needed.
I should do this more but i dont replace my bearings much. if i feel it getting sloppy then yes ill do a complete bearing replacement but avids last a while
answer has what i am looking for but i dont have an mp9 lol
