Ask Paul Lemieux, RC America/MOTIV/Gravity RC
#886
personally i would use the ceramic Thrust and the Carbide Balls. Ceramic Balls work well if your diff rings are sanded perfect to get good grip on the ball, but i would choose the Carbide balls because i feel like they will grip better naturally to the diff ring. I could be wrong but without doing more building and testing, that is what i think.
#887
diff
Paul, how do you break your diff in after rebuilding it? Do you just tighten it right up to the tightness you prefer and run it or do you just get it snug and then run a few laps and then tighten or another method?
How do you know when the diff is as tight as it needs to be?
Thanks for all your help,
JG
JG
#888
HI.
JG
#890
JG
JG
It depends how stiff this chassis is, if it is super stiff and thick i would say that you would be better off with a stock chassis for sure. if it is 2.5mms or less and just kinda stiff, maybe you can remove some top deck screws or stand offs and it will perform well.
On the T311 i feel like the stock chassis with the steering stiffners is the right amount of flex.
#891
Hi, if the Chassis is thicker than 2.5mms i think that it will not perform as well as the stock chassis. A thick chassis like 2.75 or 3mm will not have the stability that is needed for rubber tire. a softer chassis makes the car drive easier than a stiff chassis. a soft one will feel like it has more traction BC it does not allow the suspension to unload as much threw a corner and generally keeps the rear of the car stuck better. A chassis can be too soft also though and just be inconsistent threw sweepers and high load corners.
#892
Paul when will you run the '11 car on asphalt for the first time?
#893
I did run the pre production car at west coast last year, the next time i run asphalt will be at the next asphalt race. I dont know what race comes first lol. reedy race, outdoor nationals, xray challange, ? lol, sorry
#895
#896
hey paul i was just wondering what you thaught the 1 deg rear hubs done to the car over the kit version. Keeping the same overall rear toe ofcource. I no this would change the wheelbase and possibly track width slightly, but was wondering how it made the car feel.
#897
Paul do you know if these tires work on carpet?
#898
If i had 3deg all inboard the rear would stay flatter, have more entry corner steering and less exit. Inboard toe makes the rear feel stffer and has better forward traction. I like the way that the 1deg outboard makes the rear of the car roll, that is why i use them.
For carpet i use 1deg outboard a lot, for asphalt i normally run all inboard toe. Thanks!
I miss those things
#899
Hi Paul, do you have a FDR recommendation for a 17.5 TP z3r with the blue rotor? Zero timing class with a LRP SXX Stockspec v2. How about the stock red rotor? Timing setting on the can? It came at 20 degrees...
I will be running at west coast rc raceway.
Thank you in advance.
Brett
Brett
#900
Brett
Brett
I don't think Paul runs much 17.5 blinky class...lol
