1/8th Nitro On-Road - Edam Razor
#256
i think i would like to see this for the razor 2
http://www.edamhobby.com/product-det...30710-019601#p
LM
#258
bringing in the two new holes in stock-saver, the steering rods are a little clother together. I took sand-paper an made the outside a little smaler, then it works. Until now, no one of the Rodends were broken
LM
LM
#259
Is here still any Action?
Edam-Drivers still in Racing?
Leichtmetall
Leichtmetall
#260
#262
#265
A question about the Brake:
Which Brakedisc you are using? The original 3-Part Brake-Disc or the on-piece-brake-disc (Option-Part) Or is anyone using another Disc? And, how are your Experience?
LM
LM
#266
in car 1 i have the original brake settings wander badly lap to lap on the second car have the one piece it is better i also have springs installed between the brake pads which helped along with the aluminum brake arm which helped it be more consistent but is sensitive to adjustment
#267
I ask, because i changed to the one-piece-disk. With original, i had no Problems during a Race, but after each Race, i hat fo file off the little "curbs" around the pin-holes. if i forgot it, ich had problems next race. And in 2 Years, i had two broken brakecoolers.
So i changed to the one piece disk. But at first race with it, i had the problem, that the brake was after 5 fast rounds "away", so i gave a little more, and after a few rounds, i had to much brake. up and down. And, i´m not sure if it was a problem with the disk, such as the spirit had with the brake, or if it was a Problem because it was a completely new builded car with now run in from the Brake.
My Teammate changed to a another disk, i dont know which brand, and he had to change teh stopper of brakeshoe on the bridge and the chasis, because the disk has more thickness. And he is absolutely happy with it.
And i´m searching the failure
LM
LM
#268
..I was having an intermittent problem with brake disc binding when I first built the car...I shaved some of the right bulkhead away and thought I had it cured.....last club race it was binding again...maybe it's the disc....going to see what other disc may fit.....anyone ever use a carbon disc???.....pros/cons???...
#269
Problem with Brake? touching the bulkhead?
Are you sure, that you mount the brakepads correct? The Ends of the brakepads are different. be sure, that you mount the correct direction
LM
LM
