Serpent 811 Cobra Buggy
#9302
Hi guys .I am thinking of trying the Truggy shocks and shock towers on my buggy like Billy did.But i was looking in the serpent website and i did not find a setup with them . I mean i dont know what pistons and oil i should put .So if some one has tried this can you please tell me what to use .
P.s I am running on very rough track
Thanks in advance
Thanks in advance
If you would like to post your setup we can help get you going in the right direction!
#9303
I would not worry about doing what you want to do. Just putting a truggy rear tower, shocks and the right oil and pistons is not going to make much if any difference. All the guys you see doing this lately even with other cars is accompanied buy other things that make it possible and actually make a difference, sometimes good and sometimes bad. There are a lot of good setups out there that can get you close to what you want with the stock buggy parts.
front
40 shock oil
6 hole 1,4 piston
2,3 sway bar
1 degree toe out
2 degrees camber
red springs (my hobby shop has only stock front springs and red )
inserts a front 2up rear up
rear
30 shock oil
6 hole 1,3 piston
2,5 sway bar
1 degree camber
stock springs (hobby shop does not have other , he said he will order white ones)
inserts front 4 rear 5
diffs were 7 7 3 now trying 7 10 3
waiting on alu rear hubs and steering hubs
#9304
My setup :
front
40 shock oil
6 hole 1,4 piston
2,3 sway bar
1 degree toe out
2 degrees camber
rear
30 shock oil
6 hole 1,3 piston
2,5 sway bar
1 degree camber
front
40 shock oil
6 hole 1,4 piston
2,3 sway bar
1 degree toe out
2 degrees camber
rear
30 shock oil
6 hole 1,3 piston
2,5 sway bar
1 degree camber
#9305
Super Moderator
Location: a very small town in wisconsin that is in the middle of absolutely no where
Trader Rating: 63 (100%+)
My setup :
front
40 shock oil
6 hole 1,4 piston
2,3 sway bar
1 degree toe out
2 degrees camber
rear
30 shock oil
6 hole 1,3 piston
2,5 sway bar
1 degree camber
front
40 shock oil
6 hole 1,4 piston
2,3 sway bar
1 degree toe out
2 degrees camber
rear
30 shock oil
6 hole 1,3 piston
2,5 sway bar
1 degree camber
#9306
I owned both and no way the serpent will turn anywhere near what the kyosho does. If it did I would still be rocking the serpent.
?? i take steering out i have so much
i can turn under losi and the kyosho's..
yes what is the car doing and what do you need it to do better?? i run on a very rough track also.. lighter diffs will help out.. having high diff oils makes the car hyper active.. send me a pm with you email addy. i will send you a few setup to try out.. jeremy
#9307
Super Moderator
Now i know why you like the k car.. you overdrive. The k car can be pounded on and drive good. The losi and serpent you drive like wnd onroad car.. smooth and easy onthe throttle. Most guys just simply overdrive.. and yes i can turn under the k car.. ask scotty shin as i did it to him several times
#9308
are these out yet?
http://www.amainhobbies.com/advanced...ft+Set&x=7&y=7
Serpent Rear Anti-Roll Bar Shaft Set
How much different does it matter?
#9312
Yes you use the same wire thickness. I have them on all my serpent cars. I like them. Ecause they are different and the wire system does give you a 2.1 wire as an added option. I have used the 2.1 a few times. Otherwise it's the same as running the rollbar but the cool factor is way up.
#9313
car has a lot of push and flips really easy
p.s can i use mugen springs on serpent shocks .Because my hobby shop doesnt have serpent springs and i cant order from USA because the taxes are really big.So if you can tell me a UK shop that posts to Bulgaria or other shop in Euro
#9315
Hey guys I was wandering if serpent was going to release any updates or a new car? Really ready to buy another new one but I don't want to buy another car this week and they release something new the week after. Thanks
