Xray T1
Originally posted by NVisible
Ive heard of soaking them in isopropyl alcohol for up to 24 hours. Id imagine youd want to wipe off any WD40 left on the belts as WD40 loves to attract dirt
I couldnt say either way to be honest.
Only way i could see it being better is that the belts would come out clean, not needing further work... plus id imagine its quite a bit cheaper than wd40
I think Cyrul did the following trick to free up the drivetrain: cut off every other tooth in the belt.
Haven't tried it, though I'd say you'd want a belt tensioner to avoid skipping.
i filed every other tooth on the big pulley instead.
the drive train is free enough, why cut the belt or pulleys?
you can never be too free as long as the belt doesnt skip. and since it doesnt, ( i only run stock) might as well
I had the belt flip on me before, and skip when the belt was too loose.
i didnt cut the belt teeth because the smaller pulley isnt quite big enough for me to trust just a few teeth to hold it well.
Originally posted by greencactus3
really? in a crash or sumthing? oh yea, i only did this to the front big pulley too, where not too much force is req'd. and i dont brake very often either.
I dont brake in stock at my track.
brakes are for girls
JD did you get to race your car with the rear shocks on the inside of the rear tower yet? Notice anything?
Nope, no crash, just giving the car some throttle actually in my hand and it just flipped.
really? either that was a REALLY loose belt or you had some weird tension running on it. i mean, a belt running off a pulley or skipping teeth is considerable but there is no pull in a "flipping" direction.
