M8 won't turn off!
M8 won't turn off!
It just stays on. The screen and everything stays on, but the light turns on and off. It still transmits and everything, but the only way to shut it off is to pull the battery out. Help!
Did you ever drop it or try to use it as a HAM Radio?
It may be best to contact Swana/Airtronics directly.
There's a switch that says "display" it sometimes gets bumped and you won't realize it's on. It's so you can access the radio without really turning the radio "on".
I've had that happen to me.
oops, me too
But it's a cool feature to make adjustments.
Re: M8 won't turn off!
Check to make sure you have this switch off.
M8
I noticed in his original message he said it still transmitts.
He might have the signal switch engaged along with the display switch too, that will do it.
