3racing F109
#648
This may have been asked before but does the F60 body fit the F109?
Thanks.
Thanks.
#649
#651
Soon, I will calculate the cost and post it on the forum.
Thanks Steve
SMG MACHINING
#653
my new Corrally Mod
i didnt like the standard idea with the side springs so . . . .
i bought the Corrally side springs and tweek screws from their new 1/12th scale (easier to get in europe thn the CRC stuff)
i used super glue on the battom of the plastic spring mount to the chassis using the stock screw to make sure it was square with the hole , then removed the screw and screwed the corrally droop screw and ball assembly in , clipping the spring to the top of it then i can adjust the spring tension and tweek of the rear of the car
i am still trying to get the set up right as to which spring works best , suffering badly with lack of rear grip
Thaks must go to Pieter Sorber for the car , chassis and Corrally parts , Joey for the driving tips Thanks for the chance to try this car out
sorry about the pictures the Iphones camera is carp
and my car
and my car
#654
pinion size
I'm going to run a 13.5t brushless in my f109 any suggestions on what size pinion to start with would be appreciated. Got the original 98t spur (64dp)
#655
sidecarphil1
sidecarphil nice shell , what colour is it ? is it a tamiya colour ? i have some stickers on the way to me as we speak not sure what shade to pick , i like the idea of the no nosecone still look neat or have you just not got round to putting it on ? i have run mine 3 or 4 times and no matter how carefull you drive the nosecone gets hammered !!
#656
i want the nose to be yellow but being busy at work and not got to the shop for a can of paint LOL
#659
what handling problems do you have ???
i have modified the rear springs to Corrally 1/12th scale parts but they are too stiff i think
went from grip rolling every corner to rear end too loose
i need some help too
#660
@ sidecarphil1 ..
Well i run on carpet , we are limeted to a silver can motor as i said above but i cant belive how well the car runs out of the box the only mod i have is the ally castor adjuster only because it seemed the norm and what others were doing, i use addative on the rears and dial alot of steering out on my transmitter , i can seem to keep up with some of the modified drivers so cant really see any real problems .forgot to say i changed the spur to 48dp the only real reason being i had a rack of 48dp pinions and no 64s
