os speed question
os speed question
i just sent my piston/sleeve out to get pinched. i am also wanting to replace the bearings in the case. should i wait until after i break in the pinched p/s to replace the bearings, do it before, or does it really matter either way?
maybe 3 gallons on a new piston and sleeve. i let e friend use it and i think he got it too hot. thats what you get for letting friends use your stuff right lol. also when i got it back there was a little bit of really fine bust on the inside of the restrictor so it way have gotten some dust in there too. not sure if he was using oil on his airfilter. i hoping this pinch will do the trick so i dont have to buy a new p/s. seeing the dust is also my reason for wanting to change the bearings
but just to let you know on the original p/s/conrod i got almost 9 gallons out of it!!!
First of all I would never let a freind, cousin or uncle or brother drive my 500 dollar engine.
Second of all I have a speed with 11 gallons and still kickin strong.
YOU HAVE TO MAKE SURE TO LEAVE THE PISTON DBC, EVERYTIME. THEN YOU WILL BE FINE
it takes a few gallons to get them broken in
