8T 2.0 Setup sheets....post here
wrong thread
lol noticed 8t...il have to post it later..
My 2nd 8T 2.0 setup
Ride Height
Front = stock
Rear =stock
Droop
Front = -1mm from stock
Rear= stock
Sway Bars
Front = stock
Rear = stock
Springs/Shock oil/Pistons
Front = Stock/Stock/stock
Rear =stock/ 25wt/stock
Diffs
Front Diff =7
Rear Diff =2
Center-diff=20
Gearing
Gearing = 15/50
A-arms/Toe/Camber/Hubs
Front = stock/stock/stock/middle
Rear = stock/ 2-3 plate/stock/middle
Tire and Wheels
Aka = Ibeams soft
Proline- Calibers soft
Chassis & body
chasis = stock
body = stock
Electronics/Battery and Battery Placement
steering Servos = jr8711
Throttle/Brake servo = N/A
Battery = Zippy Flightmax's
Electronics = CC MMM
Engine/Pipe/Plug/Fuel
motor = NEU 1515 1Y
Pipe =
Plugs =
Fuel =
Track Conditions- Loose,dry, sandy and loamy
Ride Height
Front = stock
Rear =stock
Droop
Rear= stock
Sway Bars
Front = stock
Rear = stock
Diffs
Front Diff =7
Rear Diff =2
Center-diff=20
Gearing
Gearing = 15/50
Tire and Wheels
Aka = Ibeams soft
Chassis & body
chasis = stock
body = stock
motor = NEU 1515 1Y
Pipe =
Plugs =
Fuel =
#23
8T 2.0
Ride Height
Front = stock
Rear =stock
Droop
Front = stock
Rear= stock
Sway Bars
Front = stock
Rear = stock...testing 2.0 this weekend
Rear = Purple/ stock/stock
Diffs
Front Diff =7
Rear Diff =2
Center-diff=smart diff..(2) .15 springs ..cut 2 coils off
Gearing
Gearing = 14/45( losi steel gear)
Rear = stock/ 3-3 plate/short/forward
Tire and Wheels
stock
Aka = city blks ..med..
Chassis & body
chasis = stock
body = stock
Battery = Tekin prototype 4S 5000
Electronics = RX 8
motor = Tekin 2250 truggy motor
Pipe =
Plugs =
Fuel =
Track Conditions- hard packed sandy top, loose when dry, med grip when wet
I'll be testing 5K diff front and rear with center modified SD this weekend.
_______________
Front = stock
Rear =stock
Droop
Front = stock
Rear= stock
Sway Bars
Front = stock
Diffs
Front Diff =7
Rear Diff =2
Gearing
Tire and Wheels
stock
Chassis & body
chasis = stock
body = stock
Electronics = RX 8
Pipe =
Plugs =
Fuel =
_______________
#24
Here's a couple of me and him practicing. Yeah I know he's way faster than me. I face that fact every other weekend, and on the days we practice.
http://www.youtube.com/watch?v=yUq6rwHeEos
http://www.youtube.com/watch?v=zrXbDcw5yN4
#25
#27
those new tekins are scary to marshal especially in a truggy. i just stand there waiting to get mashed
#28
Ride Height
Front = 38mm
Rear = 40mm
Droop
Front = 109(just to make sure it doesnt extend to much over 109)
Rear=129(same as the front)
Sway Bars
Front = 2.3
Rear = 2.3
Front = black/35/56
Rear = grey/ 30wt/56
Diffs
Front Diff = 7k
Rear Diff = 2k
Center-diff=10k
Gearing/flywheel
Clutch= stock, 4 losi long-life
Clutchbell/spur gearing= 13/50
flywheel= aluminum
Springs= 2 green, 2 gold
A-arms/Toe/Camber
Front =3 out
Rear = stock
Tire and Wheels
AKA cityblock soft premounts
Chassis & body
chasis = stock
body = stock
stering Servos = JR 9100T
Throttle/Brake servo = JR 9100s
Battery = losi nimh 1100 (for now)
Radio: Spectrum DX3.0
motor = OS .21 Vspec with speed conrod
Pipe = re11
Plugs = os
Fuel = O'donnell 20%
Track conditions: Dry, loose dirt on top of hard pack, loamy, blow out, tight
Front = 38mm
Rear = 40mm
Droop
Sway Bars
Front = 2.3
Rear = 2.3
Front = black/35/56
Diffs
Front Diff = 7k
Rear Diff = 2k
Center-diff=10k
Gearing/flywheel
flywheel= aluminum
A-arms/Toe/Camber
Front =3 out
Rear = stock
Tire and Wheels
Chassis & body
chasis = stock
body = stock
Pipe = re11
Plugs = os
#29
#30
