TC3 Forum
#8791
Fan Cooling
Why not just use a traditional small ac fan or dc automotive cigarrett lighter adapter fan, then you can cool your motor, batts, and electronics, & maybe you to on a hot day.
#8792
Originally posted by Smalls
Guys real quick questions.....
If I run a rear block... R 3+2
And run Losi rear carriers that are 1.5
Will I have 1.5 degree of rear Toe?
Thanks!
Chris
Thanks!
Chris
I do not know Losi rear hubs too well, and the few times that I did use them, I used 0degree hubs. I wanted to try different rear, outter camber link locations. I know of 0, .5, and 1degree rear hubs for the Losi, but this is the first I have heard of 1.5degree rear hubs. When you install these hubs, make sure they are "backwards"(Left one is on the Right side, and Right one is on the Left side, because you want to get rid of toe), and then you will have 1.5 degrees of rear toe.
Another thing to note...
When adjusting the toe with the suspension blocks, you are also altering the wheelbase. So by having these 1.5degree hubs, and the R-3+2 block on the rear, you will end up with a "shorter" wheelbase, and 1.5degrees of toe. There is another option to try, R-2+2 with Losi .5degree rear hubs(again installed "backwards"). This has a "longer" wheelbase, yet with the desired 1.5degrees of toe.
#8793
colling fan
The fan is mounted on the car.
And to follow up the ae heat sink fan will work when connected directly to your battery, and it runs a lot faster.
#8794
cooling fan
For those same fans you can go to affilated electronics and buy them for $1.35 per fan or $13.50 per dozen.
#8795
whats up, i will be getting a tc3 once i get some more cash in my pocket but whats the best advice you can give to a newbie with this car being his first?
whats the best upgrade for this car?
thanks!
thanks!
#8796
thanks!
thanks!
Track time is the best advice! First off--get a RPM WIDE from bumper for the TC3, will save you a lot money later on.!
#8797
cool thanks but i read that the only thing wrong with a rtr car of this proformance is it dosent come with "duel steering" or something like that
#8798
with the rpm front bumper is this all i get?
http://www.rpmrcproducts.com/product...ires/80045.htm
or does it come with the foam to?
#8799
This is the bumper you will need. The foam bumper is part of the kit.
http://www.rpmrcproducts.com/product...ires/80292.htm
#8801
Bubbles, thanks...
you use the outer holes with the losi hubs, right?
#8802
I used the outter holes, and one of the good things about those hubs, is that you can also adjust the height of the ballstud(vertical). Eye balling everything, the inner hole on the Losi hub is close to the outter hole on the Associated hub, but they have a slightly different height. I forget if you have to raise the ballstud, or lower it when using the Losi hubs, but they're not EXACT.
When driving the different hubs, I noticed that the Associated hubs make the car slightly more edgy than the Losi ones(when using the outter hole on both hubs), but the car would rotate better through the corner.
#8803
I have been racing my TC3 for more than 4 1/2 years. Heres my first one I still race, im keeping this one forever...!!!
TC3 #1 ...
Heres mine!
TC3 #1 ...
Heres mine!
#8804
TC3 #1 ...
Heres mine!
TC3 #1 ...
Heres mine!
#8805
One way
I can't seem to find a one way for my elec. TC3 anyone know where I can get one. I already looked on the Team web site Couldn't find it??????????
