how to run in AAC
Old 04-12-2009, 10:10 AM
Default how to run in AAC
Hi
Method for running in AAC please ?
xtreme888 is offline
Old 04-12-2009, 11:01 AM
Roelof's Avatar
Start with removing the head and just use the burnroom (maybe you need some M4 spacers to screw the burnroom tight).
Start te engine and run rich with a temperature of 80 to 90 Celcius.
After some tanks mount the head again and go on with the procedure on 80 to 90 Celcius.
With AAC engines we have several cooling heads and build it up to the right head and that is giving very good results.
Roelof is offline
Old 04-12-2009, 11:21 AM
wingracer's Avatar
Trader Rating: 24 (100%+)
Good idea there Roelof. I will have to try that (if I ever run an AAC motor again).
Most important, take your time.
wingracer is offline
Old 04-12-2009, 12:16 PM
Roelof's Avatar
It works also with ABC engines
Roelof is offline
Old 04-12-2009, 04:12 PM
GREGORY!'s Avatar
do you preheat them too?
GREGORY! is offline
Old 04-13-2009, 01:36 AM
Roelof's Avatar
Ofcourse, that is always needed with new engines.
Roelof is offline
Old 04-13-2009, 03:04 AM
Trader Rating: 101 (100%+)
Default Run in
I had great results wrapping foil around the head and running in non-stop at 220 f . I made a gallon jug up with parts from a airplane fuel tank. I have over 3 gallons on it and it's been fast . The break in I used is in the RB forum.
latemodel13 is offline
