The Speed Passion Thread
#5236
But if you use the ZERO timing soft, there is no danger
Regards,
Adrien.
#5237
#5239
I'm not here to start any internet wars over ESC's in toy cars, but I do want to understand the proper functionality of the 528 SW if it indeed differs from the method I know. Being an Electrical Engineer, I enjoy the technology side of these new ESC's and want to ensure we all can benefit from the proper understanding of their functionality.
Thanks,
Jimmy
#5240
Jimmy, your Excel sheet's formula worked correctly. I believe Irgo was just trying to point out that the values for the Start RPM need updating. Due to SP changing the values for the 528 release.
No one is taking away from your work, I'm sure I speak for many when I say it's appreciated.
When are you going to release worksheet v1.01? I still use your 422 version.
#5241
Jimmy your Calc for 528 is need correction.
1) at "DMTS Start RPM" it's not 528 but it's 422.
528 is :
4000,5000,6000,7000,8000,9000,10000,110000,12000
2) "DMTS START RPM" supposed to change as DMTS Timing Change.
and DMTS START RPM is defined before SC Timing is Activated,
and timing and end rpm change again.
3) "DMTS Timing" has no relation to Supercharge Timing Punch. (miss calculate)
4) "SC Timing" has no relation to SC Timing Punch. (miss calculate)
5) "SC Timing Punch" has no relation to SC Timing Punch either DMTS Timing. (miss calculate)
i'm sorry but your calculator is all wrong.
528 is :
I'd be happy to release an updated version, however if the method of determining the RPM window is incorrect I would like to understand the proper method and implement it within the updated calculator file.
Jimmy.
#5242
Attached you will find the calculation for End RPM. It's from a reliable source, Speed Passion Co.!
Awaiting your revision.
#5244
Jimmy, all in all, Irgo means well. Just misunderstood by most here on this thread.
#5246
Lets say you have 40 degrees of timing programmed and 0 motor timing. You then create the RPM window for that timing to be applied.
Start RPM 3000 : End RPM 6000 This would provide a very steep slope to the timing curve to come in as you start at 0 timing at 3000, and by 6000 you reach 40.
Start RPM 3000 : End RPM 16000 This would reduce the slope of the timing curve as you start at 0 timing at 3000, and by 16000 you reach 40.
Getting the amount of timing with the slope of timing curve tuned in and the proper gearing will result in a fast setup with motor that keeps the magic smoke inside .
Hope this helps.
Jimmy
#5247
SAN, This is first part of the message where the overall method was defined as incorrect.
Jimmy.
Jimmy.
you can correct me if i'm wrong, and i have been testing your calculator.
it's good idea.
maybe not everything is incorrect, you can decide it your self,
I thought you must add both RPM Start, as 528 and 422 start RPM
must be a defined,
another thing is that if you would like to use DMTS included in to calculated
formula, you may need to change RPM Start as well,
if the result for RPM DMTS not equal to RPM Start, the next is
supercharge boost and Punch will not activated, and so the End RPM is false,
on your calculator.
my suggestion is to calculate RPM Start = DMTS RPM.
as "RPM START" is the result of your calculator.
Note: when DMTS is reach it's maximum degree as defined ex:0~21°.
remember that DMTS is Dynamics.
Example : if max 21°DMTS rpm is 8000rpm then the start rpm defined is 8000rpm,
but when you change max 18°DMTS rpm is 6000rpm your car suddenly become slow, as Supercharge is not activated. and your End RPM stuck there
at 6000rpm.
#5248
Example : if max 21°DMTS rpm is 8000rpm then the start rpm defined is 8000rpm, but when you change max 18°DMTS rpm is 6000rpm your car suddenly become slow, as Supercharge is not activated. and your End RPM stuck there
at 6000rpm.
at 6000rpm.
Start RPM = 8000: 0 timing
Mid point RPM = 15000 (8000 + 22000) / 2 gives 10.5 timing (21 / 2)
Calculated End RPM = 22000: 21 degree timing
Thats my 0.02 on it all. If it is incorrect, please provide the examples to determine the correct operation.
Jimmy
#5249
ex: when the Timing Reach max 21° your RPM is able to reach 8000RPM.
that's your start RPM is.
Remember that Speed Passion is designed Start RPM to activate SuperCharge.
#5250
Item #9 DMTS Timing: It is effective throughout the entire throttle range and affects the motor speed in the entire track. Please note this refers to the maximum value of the ESC internal timing, the actual timing is always dynamically changed every moment according to the motor RPM.
Item #12 Super Charger Timing: It is the additional timing that added to the DMTS Timing and only effective when the throttle is fully opened, so usually it is useful for long straight track.
Item #14 Super Charger Delay: This is the time that must expire at fully opened throttle to engage Super Charger. If the fully opened time of throttle is less than the setting value, the Super Charger will NOT be activated.
Item #13 DMTS Timing Start RPM: ESC begins to increase the internal timing when motor speed reaches the DMTS Timing Start PRM. A lower DMTS Timing Start RPM setting will produce a faster rate of Super Charger because the ESC increases the internal timing earlier.
Item #15 Super Charger Timing Punch: This refers to the RPM increment that triggers the ESC timing increase of 1 Degree. A lower Super Charger Timing Punch setting will produce a faster acceleration and hotter temperature of the motor.
Setting #13 does reference the SC timing, however it is defining its slope as well (just like Tekin Turbo Ramp setting). The ESC does not just dump SC timing onto the motor, it creates a ramp using the DMTS timing setting as well.
All of my information is based on this published data. If you know something different about the operation please share.
Jimmy
