stuid radio
I use my CS Space Charger Pro to charge my batteries @ 1a also
and can anyone tell me when the low voltage alarm is activated on a JR XS3
I don't now for sure...but my R1 is at 9.0V...they are both JR radios..so I'm guessing it will be somewhere in that ballpark...
if you hear the alarm though..you've already pushed it too far and you need to get onto a charger or put your backup batteries into your transmitter...
The new batteries are NiMH...so you may as well charge them early as opposed to running them down since you don't hafta worrry about cell memory
i will just charge the batteries at the track before racing starts so i dont have to worry about the batteries from getting low
Thanks for the help Guys
*WADE*
*WADE*
#21
do you have to make a special connect to work with the charger or do you just use alligator clips some how.
#22
It all depends on the battery tray...
my R1 has a connector that is the same as a servo connector, so I used a servo extension wire to make a connector and hooked Alligator clips to the other end...
Another trick you can do is remove your tray and put battery bars between the battery and the contact at the ends and hook your clips to the battery bars...
One more thing you can do, if your radio does not have a removeable battery tray, is get a battery tray from your LHS...they are inexpensive and allow you to charge your batteries while not having them connected to your valuable electronics...
