Kyosho Evolva
#497
To get 2 degrees of camber the plastic joint is almost flush with the arm (maybe 1mm outside the arm) [/B][/QUOTE] See the attach pic
#498
Originally posted by raceblast
I understand. As I said before, the plastic joint (that connects to the turnbuckle on the rear upper arm) ought to be adjusted half way out of the upper arm to have 263mm track width and 2 degree camber if Mugen/Kawahara tires are used. Because the plastic joint is extended out, it is easier to be damaged if the rear wheel(s) suffer impact.
This problem may not exist if Kyosho rims are used. I heard Kyosho rims have different offset than Mugen and Kawahara rims.
My rear camber link extends past the bracket less than 1mm and I have 262mm rear width.
#499
Try this one
#500
Mine's the same and so is the camber link.
#501
The Kyosho rims fit the Fantom....the previous 1/8th scale car. For the 2003 (or 2004) you have to use the rims designed for the Mugen.
That last track width (362) must have been a typo
#502
rjl....I sent you a PM
#503
Got it, and fixed the dumb finger thing.
#504
I was setting up the rear end on my car and I was able to get 262mm trackwidth, 2 deg. camber and 1.5 deg toe in with the ball end flush with the outside edge of the upper arm. My car is a Delta, although I don't think it makes any difference. This is all with the stock tires as well as Mugen Fast tires.
My car didn't come with a setup sheet so can someone point me in the direction of setup sheet online? Also, what is the stock ackerman horn and what is everyone using?
#505
http://www.kyosho.co.jp/main-e.html
#506
When I disassembed the clutch, I found that the clutch shoe is uneven worn. One side is thinner. How can that happen?
#507
#508
What may cause the clutch disk/plate to be not flat?
#509
Far too much heat, you may have been running your engine too rich or have too much gap between the bell and the clutch shoe. I have thrown a flyweight trying large gaps.
Or maybe like mine, I picked up a rock in the spur gear that caused the inner bearing to fail. It happens.
#510
L Think This Car Is Bit like A V-ONE-RR-EVO Just But its A Smaller Size L am right or not
