NEW NOVAROSSI 2009 ENGINES
Old 11-15-2009, 06:03 PM
  #256
Michael_T's Avatar
Trader Rating: 52 (100%+)
Originally Posted by Jason Smith
Just got my 09 353! It came with an extra top end needle...can anybody tell me why?
Jason, the extra needle is an optional tuning part (more agressive). Don't ask me how it works, never used one.
Michael_T is offline
Old 11-15-2009, 06:05 PM
  #257
Michael_T's Avatar
Originally Posted by servo
i had a bad problem...
yesterday i've check my Flash .21 engine...open the back plate and found rust at my con rod and main bearing...can anybody advise me what should i do...???actually i've ran that engine every 2 week...
i'm using tornado fuel 25%...
is it not good to used that fuel...???
Are you sure it is rust? Can you post a pic?
Are you draining fuel and adding after-run after each meet? Even if you didn't, I would be suprised that the engine could rust up in 2 weeks...
I have been running Tornado for awhile now, never had a problem with it.
Old 11-15-2009, 06:14 PM
  #258
wingracer's Avatar
Trader Rating: 24 (100%+)
The rod is aluminum, it won't rust. The bearing and crank could though.
It's probably dried up, gummed up caster. Pull it down, clean everything real well, lube it up and put it back together.
wingracer is offline
Old 11-15-2009, 06:31 PM
  #259
servo's Avatar
thanx...will post it up tommorow...
will try it soon...thanx for the advise...
can i use sand paper to clear it out...???
servo is offline
Old 11-15-2009, 06:32 PM
  #260
lil-bump's Avatar
Trader Rating: 89 (100%+)
jjj
lil-bump is offline
  #261
jca2000au's Avatar
Trader Rating: 9 (91%+)
Did you put any after run oil?
jca2000au is offline
Old 11-15-2009, 06:54 PM
  #262
Michael_T's Avatar
NO
I agree with wingracer, I have seen a few bearings (both Novarossi and other brands) with gummed up castor which does have the dark brown colour similar to rust.
Lets see some photos first.
Old 11-16-2009, 01:08 AM
  #263
M7H
M7H's Avatar
Depending on the age of the Tornado fuel, because "older" Tornado fuels (5 Liter cans) don't have castor oil in it, it is a full synthetic based fuel which burns completely clean. After run oil very much recommended.
There where 5 Liter cans of the so called "Sydney formula" which had a percentage of castor oil in it, and the latest Tornado fuels which came in the 4 Liter/1.06 Gallon cans are based on this "Sydney formula"...
But still I ALWAYS with ALL fuels recommend people to use after run, after every meeting and even if you are going to use your engine the next day again.
Have you check the price of a bottle of after run?
that's why I use almost 2 a year.....
M7H is offline
Old 11-16-2009, 03:55 PM
  #264
servo's Avatar
hi there...
actually i used tornado after run oil and keep it about 3 week without started it...
this are some picture of my internal engine...hopefully any experts here can help me on this...
what should i do..with what meterial should i use...???
Attached Thumbnails NEW NOVAROSSI 2009 ENGINES-img_4190.jpg   NEW NOVAROSSI 2009 ENGINES-img_4202.jpg   NEW NOVAROSSI 2009 ENGINES-img_4213.jpg   NEW NOVAROSSI 2009 ENGINES-img_4214.jpg   NEW NOVAROSSI 2009 ENGINES-img_4192.jpg
servo is offline
Old 11-16-2009, 04:09 PM
  #265
wingracer's Avatar
Ew, that is nasty looking. If it is just castor, soak everything in alcohol for a bit and everything should just wipe off with a cloth or toothbrush.
Old 11-16-2009, 04:47 PM
  #266
Michael_T's Avatar
I wouldn't bother cleaning it. Just replace the bearing and rod, the crank looks ok.
Did you add additional castor/oil to your fuel mix?
Old 11-16-2009, 05:16 PM
  #267
servo's Avatar
nop...just used oil from factory...after run the engine i used to open the back plate...clean the inetrnal with nitro buster and add after run...last month i didnt start the engine about 3 weeks...
replace the bearing and rod is the best option...???
i was thingking to put it in coke...
servo is offline
Old 11-16-2009, 05:47 PM
  #268
Michael_T's Avatar
Nitro Buster????
Are you talking about this:
I was under the impression this was an external nitro residue cleaner
Old 11-16-2009, 05:53 PM
  #269
Trader Rating: 15 (94%+)
the rod shouldnt rust as its brass/aluminium..the rust will be coming off the crank
use scotch brite to clean it all up and then use wd-40 to spray it all clean. then methylated spirits to get rid of the wd40 as that stuff stinks
then oil it up. just soak it with after run oil. if you think the oil is too thin then go with power steering oil
mrgsr is offline
Old 11-16-2009, 05:54 PM
  #270
Tech Prophet
houston's Avatar
Trader Rating: 96 (100%+)
Talking
Nitro Buster????
hey guys , i got a 1/2 gallon old onroad crank i believe is either from a 359 or 35plus21 , whichever one uses a 4.5mm crank pin . it is a ceramic coated , hotmods putty filled crank . very spendy crank , if you want it you can have it for 90$ obo
pm or email me
[email protected]
houston is offline
