Pro-match Batteries
Old 02-11-2004, 05:09 PM
  #646
jsp
Have you guys seen ProMatch's new soldering job/ process. Very impressive with no extra solder. It is the cleanest job I have ever seen. Their website talks about the process but they need to show a picture. I actually watched one of their techs named Steve do the job. This is why ProMatch is # 1.
john
jsp is offline
Old 02-11-2004, 06:22 PM
  #647
Salvadori and promatchr - Thanks for your advice!
zgeist is offline
Old 02-11-2004, 06:32 PM
  #648
jaysimpson's Avatar
Chill: I will try to soon.
jaysimpson is offline
Old 02-12-2004, 05:19 AM
  #649
Chill Will's Avatar
Chill Will is offline
Old 02-12-2004, 12:57 PM
  #650
I'm confused about the Integy reactor 30 that some of you use. This is a response from integtythat I just received when I asked the what the cut-off voltage is:
The Reactor 30 works fine the way it's setup from the factory. It stops the fast discharging at about 4V. The stock setup works great with 4 cell and 6 cell packs. We had no reported battery failure with the default setup. However, if you really want to adjust the cutoff point...you'll need to open the unit case (may void warranty) and adjust the VR knob while the unit is discharging and you'll need to hookup a voltmeter to your battery pack's terminal to monitor your pack's voltage. A non-matched battery pack need higher cutoff voltage like 0.9V/cell.
Best Regards,
Tech Support
Is everyone adjusting the voltage to 5.4v?
Razoo is offline
Old 02-12-2004, 01:02 PM
  #651
highwayman's Avatar
Razoo: I, personally discharge to only 6 volts, because at 30amps, i found that sometimes, a cell goes below .90 volts, if the cutoff is at 5.4... but thats just me.
highwayman is offline
Old 02-12-2004, 01:03 PM
  #652
Hi Razoo,
Good question, on my Integy unit I adjusted the voltage to 5.4 volts with the internal pot. The only problem with doing this is you basically can't discharge 4 cell packs with it since their voltage is already below 5.4 volts. I've been using it for a while adjusted this way and it works fine.
Ozwald Bates is offline
Old 02-12-2004, 05:34 PM
  #653
Chill Will's Avatar
Ok........ Who are you? The real Ozwald wouldn't answer like that.
Old 02-12-2004, 06:44 PM
  #654
Thanks for the replys, I just won a reactor 30 on ebay and when I get it I'll adjust the voltage to between 5.4-6.0v. I wonder how many people are using them thinking they are discharging to 5.4 without making the adjustment.
Razoo is offline
Old 02-13-2004, 03:28 AM
  #655
jaysimpson's Avatar
I would think alot of people aren't aware.
Old 02-13-2004, 10:33 PM
  #656
Hebiki's Avatar
Trader Rating: 26 (100%+)
how do you adjust it? i have a reactor 30..and never knew about that feature?
Hebiki is offline
Old 02-13-2004, 10:52 PM
  #657
Neil Rabara's Avatar
Hebiki, here's your answer. Just a few posts up.
Neil Rabara is offline
Old 02-13-2004, 11:03 PM
  #658
Trader Rating: 16 (100%+)
Default Pre-Built Pro-Match batteries
Just got my first set of pre-built Pro-Match batteries from my lhs. Have previously built all my battery packs myself with good results; but, I really liked the workmanship of the bar connections between the 6 cells
However, I cannot imagine why Pro-Match isn't installing a 90 degree bar on the 1st and 6th cells so users don't have to solder directly on those cells to make connections. This seems to defeat the concept of pre-built packs with superior professionally done connections between the cells AND at both ends.
Why not go all the way with bars on both ends like Fusion Power's pre-built packs?
Still Bill is offline
Old 02-14-2004, 03:40 AM
  #659
XXX-S Bill, I'm pretty sure they did that so the user has the option to use whatever connection is applicable ie; connectors, hard-wiring.
ZER01 is offline
Old 02-14-2004, 04:00 AM
  #660
jaysimpson's Avatar
proudwinner: You are correct
xxxsbill- I am sure next time if you request that those bars be installed they will take care of it. Hope you like them!
