Serpent 710
#2986
Originally posted by nad138
Talking about Serpent's "corporate" colors, here's mine :
#2987
Originally posted by InitialD
Yeah, if that was true, then RB and NovaMax would also supply you their engines !
#2988
Re: Re: Re: Setups?
Originally posted by S710_Nut
I am using the solid diff at the front and have already disconnected the rear sway bar and this made a bog difference.
SN
SN
#2989
Ummm, Ok. I think Thaasman had the same problem mounting his receiver. Julius gave him a suggestion which seemed to work well (I think). Julius posted a pic of how the receiver box should be cut to fit the wires and crystal.
What i did is i cut not only the red part, but the whole thing!
It should be no problem because the reciever will be well protected and cant get out or move when the protector-box is mounted...
RCJAY: if you want i can post some pics....
#2990
Re: Re: Re: Setups?
SN
SN
Hook up the rear sway bar again and set the two aluminum collars with set screws so that about 3 mm of the sway bar sticks out past the collar, and give this a try.
If you're going to disconnect the sway bar to reduce the push, you want to disconnect the front one.
#2992
Fast Harry Posted; speakin' of yummy.....have you been racing with us at johns in nanuet?..
No Harry, I'd love too...E-mail me the address and phone#
#2993
Hi!
#2994
Steering Arms
Originally Posted By Goldfinger:
D, with this setup, do you know how MS mounting the (track rod)ball end ? on top of arm saver(like us) or bellow the saver (like in the book) ?
Last week, my 710 is handling very differently.
And last night, I just found this:
With 0 deg toe in, 1.5 camber, 6mm setup ride height
Ball end mounted on top: maximum turn is 25.5 deg(inside tire) and 14 deg(outside tire)
Ball end mounted bellow : max 24.5(inside), 15.5(outside).
In real condition, as the car leans hard (1 side of chasis hit the ground) the inside tire angle is increase about 2 deg and the outside is reduces about the same value.
As you can see the ackerman is angling so extremely.
I think this is playing a big part to resist the car to turns tighter, coz the tire slip angle amount is too big to overcome.
Please share your thought....
I kind of feel the same way, and appears to make sense !!
I would also like some input on this issue !!! Ideas/Tips/Trick/Good/Bad ????
#2996
Re: Re: Michael's Setup Sheet for Srinakarin Track in Thailand
#2997
This is what Bruno Heeramans has got to say about Ackerman...
A large Ackermann angle (ball joints above the servo saver) gives you smooth, predictable steering. You'll be able to round the corners nicely without all four tires trying to force the car in a different direction. A smaller Ackermann angle (ball joints below the servo saver) on the other hand can give you more aggressive steering, aspecially entering the corners. However, it isn't guaranteed that the front won't wash out now and then. Neither is a smooth cornering radius. It can be useful an high-traction tracks, if your car tends to oversteer in the middle of the corners, and you'd like a little more turn-in. Not to mention the psychological impact on the person driving right in front of you when you're entering corners.
#2998
I got the recevier in, thanks guys for all your help
#2999
#3000
I did what Thaasman posted but I had to move the cut up a little but it worked and im happy once again
