Novarossi RS12TS3 settings
top/high end 5 1/4 turns out
Depending on what fuel you run, you might need to go in up to about 1/2 turn on the top. These are basic needle settings, just remember to keep it smoking!
if the idle is too low, it will stall, but if the idle is going up and down or running a "pattern", you have an air leak. If it will idle smooth but then stalls as soon as it gets warm, you might have a "pinch" issue or some dirt in/on the needles.
