What do you guys recommend?
its the opposite dude ... NTC3 is setup out of the box (foam and rubber using the same springs and oil) ... MTX3 needs a little work to change from the super oversteer setup the Japanese use. Just like the MBX5, nobody uses the stock setup not even the pros as it plain sucks and causes the car to whip around like a tether car. Oversteer on highspeed corners, and understeer on low speed corners with the MTX3's stock setup.
I've owned both as well
p.s- I wouldn't consider the NTC3 a pro level kit .. I consider it a club racers kit. Perfect for club racing -as long as you don't have a relationship with the boards - MTX3 is a pro level kit, meant for pro-level tracks and surfaces.
the Team driver dont use the stock set-up for the NTC3 either
in fact for the front shock tower mount, they use the hole that is ment for the body post in the rear
most of them use a heavier shock oil in the front aswell
Fair enough ... my point though, was that atleast with the NTC3 the stock setup works well. It can always be tweaked, but atleast it works. The stock MTX3 setup is just way out of whack :P
#20
actually .. looking through the setups again on AE's site, the team drivers on a majority of the tracks are pretty darn close to copy of the setup in the manual. With some small changes, nothing too far .. and all of the shock tower mounts are as mentioned in the manual too. Don't see any listed on AEs site anyways, that show the wild shock mount position you mentioned unless I missed it
#21
I thing Kyosho V-one RR EVO is more solid than mtx3. Its really very tough and I do recommend to beginners like myself. It handles very well too. Already check with those who own both MTX3 and EVO, they all says kyosho is more forgiving..
#22
Go for what ever car your LHS carries most parts, as a beginner there is a steep learning curve and breakages do happen.
#23
I agree with Finchy its waste point buying a car and then not being able 2 get parts 4 it
#24
look at the first set-up on this page
#25
haha punk so I didn't know about those ... ahh well!
