Picco Evo 2 settings
Im running a McCoy MC9 (cold plug) O'Donnell 30% race fuel, Standard plug non turbo, Standard Picco Evo 2 P7R .21 with a JP 3 pipe.
I can not get a handle on this motor, i get good smoke all threw the power band but when i get high RPM it gets real smokey and dies. So im thinking a little rich but my temps are 230 or so and its 80 ambient temp here. I think my problem is that im tunning to temp instead performance. As long temps dont really get over 260 to 270 right? then it starts getting dangerous...
And im not sure what venturi is in the carb but is there any way to tell and do i have to run one?
Thanks Lance
Thanks Lance
needle setting's mean Jack from location to location.....picco/jammin needles are like most....flush on the top end....and a turn or so OUT on the bottom.
ps get the turbo head button and you'll see a significant increase in power.
ya sure...
button
http://www.nitrohouse.com/catalog/pr...ducts_id=12843
Trinity Phatt head
http://www.amainhobbies.com/product_...ducts_id/16561
the Stock Jammin head is also 80$....so the trinity is the solution....or i guess u could go with those Fugly Chrome one's from Nova.
Thanks for the fast responce!! I have never delt with many Picco engines.
What do you recommend on temps or should i just tune for performance, but of course temps over 280 are dangerous. Im using a infared gun with laser pointer and i check the whole glow plug area back and fourth and never one spot and i look for the hottest temp i just don't point on the glow plug it self because it seems its one of the coolest spots inside the head. Is this the correct way of getting temp or should i just point at the plug and will there be hotter temps threw other parts of the engine?
Thanks for the help!!! Im new to the site but likeing it so far!!
Also to add i removed the head button to see what shims there are and it only has one shim and its really thin prolly a .01mm shim do i need more shim for 30% nitro and im also running a McCoy MC9 plug which is a cold plug should i run a MC8 or should i go to a Picco Plug?
