Original RC10 stealth tranny slipper
Does anbody know if I can fit a newer B3 or B4 slipper on the 1st generation stealth? Thinking about converting to RPM 2.65 tranny too. Thanks
The B3 slipper shoud fit. The same top shaft has been used since the RC10 Worlds' Car (p/n 6571).
The B4 uses a new top shaft (p/n 9601)
The B4 shaft DOES fit, you need to keep all the double slipper items (both slipper pads, gear & slipper disks).
For the RPM tranny, your only chance of using B4 gear is finding a rare Losi Hydra Drive top shaft, then there is enough room for the double slipper set up.
The B3/T3 set up is a step above the OG stealth & B2 hardware.
Sweet! So a B2 gear/dust cover plate should work with original stealth? Thanks alot!
As far as I can remember the slipper and the cover are first generation only, unique to the orgional stealth.
You can get the rpm case and gear directly from rpm, and tower and I think great planes too, still carry the orgional slipper parts and pad. I recently bought all of the parts to rebuild the diff and changed the sipper plates and pad.
if you use the rpm case you will be good but if you use the associated case you may have to either cut a hole in the bottom of the chassis for the transmission to fit or raise it up with washers or spacers.
