Fukuyama Batteries
#5011
Ran my 1.17+ fukuyama cells yesterday and they were awsome. I TQ'd and won the 3rd round of the Tamiya Eurocup here in the UK and had loads of duration left in my cells at the end of the runs. Rick
#5013
Well Team Fukuyama showed very well this weekend at the Tulsa Invite. Chris Tosolini finished 2nd to Baker in a "Reedy Race" type race format of 8 races/ heads up. Chris lost out by one point and had a really good weekend. Curtis was there with some Fukuyama Mods....OH MY they had some pony! Look out with some of that strapped into you car. Curtis had a great weekend behind the wheel as well. Had a blast pitting and running with those guys in the invite.
Also Stephen Sobottka was the 19t winner I believe with some Fukuyama batts.
Impressive weekend for sure.
Jeff
Jeff
#5014
Charging Question
Hi!
I would like to get some tips on charging my fuku cells. What charge amps and delta peak are you guys using? I am using a Pro Track Charger.
Thanks in advance!
Thanks in advance!
#5015
Gido - Depends on what you're running. All my charging is based on touring car racing, it could be different if you run off road.
Stock - 6 to 6.5 amps charge with .04 to .05 peak detect. Cells should be around 130-145ºF after the peak.
Mod - 5 amps with .04 to .05 peak detect. Same temperature is applied to the cells after the charge, but with the 5 amps you'll have longer runtime and just a hint less of voltage. Voltage isn't an issue with mod motors, but crutial with stock.
Also, if the cells are getting to hot, reduce your peak detect.
Hope this helps.
John
Hope this helps.
John
#5016
Special Notice
Dear Team Drivers,
Those that are planning to attend this years Reedy Race, please contact me via Email within 48 hours to get your team Spec Pack. After 48 hours, all packs will be retailed to Customers and Shops. Thanks.
Dan
Dan
#5017
I just returned from the OK TC Champs.
I top qualified both Expert stock and 19t for Team Fukuyama. I won the 19t class with a perfect score of 200, i won the first 2 a-mains, letting me sit out the 3rd.
I had some rough luck in the first stock main with a 5th place finish. I won the 2nd a-main, and took 3rd in the last a-main. It gave me 2nd place overall in expert stock.
Thanks Dan! The packs were awesome like always.
#5021
Re: Special Notice
Originally posted by Maj. Teeth
Dear Team Drivers,
Dan
Dear Team Drivers,
Dan
ill send you an email when i get off work dan. hope u like what i did.
#5022
#5024
steve always does well at big races, great job buddy
lazy
lazy
