Centax 2 nut keeps coming loose >
Old 07-22-2008, 04:11 PM
Default Centax 2 nut keeps coming loose
The spring tention nut on my Centax 2 clutch comes loose during the mains (any longer than 5 minutes) how do you keep constant tension on this nut for an entire 30 minute main.Locktight? if so what kind and how much?
cmego is offline
Old 07-22-2008, 04:14 PM
GMartinez's Avatar
Trader Rating: 91 (100%+)
Double check the collet it might be 2 long prevententing a proper tightness or simply change the nut
GMartinez is offline
Old 07-22-2008, 04:55 PM
Over time the nut might develope some slop. You can get a new nut or you can apply a small amount of threadlock, but dont overdo it.
Maxx is offline
Old 07-22-2008, 06:05 PM
lil-bump's Avatar
Trader Rating: 89 (100%+)
If you decide to use locktight I recommend the blue stuff. I would not apply the locktite wet. What you want to do is apply a small amount of locktite to the threads of the flywheel nut and then let is dry totally. Then assemble the spring with the spring nut. The dried locktite should offer just enough drag on the nut so it won't back off. Another thing to check for is burrs on the spring nut. Also if your clutch is allowed to overheat(Hot Hot) this also would cause your nut to back off.
Pass you soon...
lil-bump is offline
Old 07-23-2008, 10:11 AM
R/C Tech Elite Member
JayL's Avatar
also check the nut isn't rubbing the bell, no burrs etc.
JayL is offline
Old 07-23-2008, 11:02 AM
Roelof's Avatar
Be sure the nut has no damaged edges sticking out, they could be grabbed by the hole of the clutchbell, just grind the edges.
Roelof is offline
Old 07-24-2008, 12:12 AM
Thanks for the input.
Modelspeed
cmego is offline
