Ceramic bearing ?'s
Ceramic bearing ?'s
I orderd front and rear ceramic bearings for my motor and the front bearing comes with rubber seals on both sides.Do you guys run them with both seals or do you remove the inner seal?I don't really understand the specs boca listed because it is sealed and they are saying that the rpm limit with grease is 50 and with oil it is 59.I don't see how you could get oil in there if it is sealed on both sides?I was also told that ceramic bearings need a special break in procedure?Thanks
MR607C-2RS TH9/C3 Details
Item Information
Click to enlarge
(Not Actual Product)
Part Number: MR607C-2RS TH9/C3
Product Type: Radial Bearings
Description: Chrome, Ceramic Hybrid, Rubber Seals, Polymite Retainer, C3 Fit
List Price: $37.95
Your Price: $37.95
Sale Item: -
Qty. In Stock: 6
Qty:
Top of page
Item Specifications
Bearing Material Chrome Steel 52100
Rolling Element Mat. Ceramic SI3N4
Dimension Type Metric
ID (d) 7
OD (D) 19
Width (B1) 6
Extended Width
Flange OD (D1)
Flange Width (Bf1)
Groove & Snap Ring
Enclosure # Two Seals
Enclosure Material Rubber Seal
Enclosure Type Contact Seal
Retainer Material Polymite Plastic
ABEC/ISO Rating ABEC#1/ISOP0
Radial Play C3
Lube Kluber L55 Grease
RPM Grease (x1000) 50
RPM Oil (x1000) 59.4
Dynamic Load (Kgf) 238
Basic Load (Kgf) 91
Weight (G)
Working Temp Deg C 121
Weight(g) 6.63
Item Information
Click to enlarge
List Price: $37.95
Your Price: $37.95
Sale Item: -
Qty. In Stock: 6
Qty:
Top of page
Item Specifications
ID (d) 7
OD (D) 19
Width (B1) 6
Extended Width
Flange OD (D1)
Flange Width (Bf1)
Groove & Snap Ring
Radial Play C3
Basic Load (Kgf) 91
Weight (G)
Weight(g) 6.63
I have never used the Boca's but have had excellent results from TKO ceramic engine bearings. I use both seals on the front bearing.
Oh, and oil will find its way in there seals or not.
If you are running offroad then it is wise to keep the seal on the inside.
I am not so into the ceramic bearings. I must say the one in my JP Eagle is running great, even after 15 liters but if it was a good steel one I would be also happy with it.
I know for sure if the bearing got some play I will go for a original steel one, the gain in performance on paper seems to be awesome but on the track there is no difference, for sure if you are no topdriver. Beside that, 100+ euro for a ceramic bearing or 40 euro for an original steel is making 60 euro difference....
Regarding the front bearings that is not making a difference at al if it is steel or ceramic.
I know Boca makes good affordable ceramic bearings but I also have seen some problems with exploding balls which makes me think twice.
I too was hesitant to embrace ceramic bearings but TKO is starting to turn me into a believer.
