HPI R40 Nitro Car Forum >
Old 04-30-2007, 05:02 AM
  #11461
fastharry™'s Avatar
Originally Posted by Artificial-I
Yeah just to let everyone know. If you die and goto RC Heaven. You actually end up showing up at fastharrys place in Jersey.
thats true...hows that red dot working?..
fastharry™ is offline
Old 04-30-2007, 06:18 AM
  #11462
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Havent run it yet. Might on the next local CR on the 6th. I had an older picco that was a pretty good motor when I last ran it. So I went and got it out , modified it to be similiar to the red dot. I have a good feeling it should perform well. As far as the reviews go , most everyone whos run the red dot is more than happy it seems. Great value and top performance.
Artificial-I is offline
Old 04-30-2007, 01:00 PM
  #11463
Default yes yes
Originally Posted by nitrohead5300
.......................Are you going to put that in a R-40 by any chance?? If you do = warpspeed!!
of course i will. i put every metal hype in this car 150.00 bucks of metal . i check the weight and get back to you.
LORD SHADO is offline
Old 04-30-2007, 01:03 PM
  #11464
Default fly wheel pins
fly wheel pins / whats this about shaving down the 4 fly wheel pins . help artifical intellegents. i have the mugen shoe and the spring help me im working on the clutch.
Old 04-30-2007, 01:04 PM
  #11465
Rapid Roy's Avatar
Sometimes the pins are too long and touch the clutch bell. I don't shave them. I tap them in further lightly with a hammer. Just place the flywheel on some wood (NOT your dinning table) and they go in nice and easy.
Rapid Roy is offline
Old 04-30-2007, 01:29 PM
  #11466
fastharry™'s Avatar
well,if it doesn't weigh this,its all show and no go......
Old 04-30-2007, 07:12 PM
  #11467
hey ya missing some bling
1 x 3Racing (#HR4-026) Brake Stopper Pulley 19T For R40 (HR4-026) = USD$12.50
1 x 3Racing (#HR4-022) Aluminium Pulley 18T For R40 (HR4-022) = USD$10.90
1 x 3Racing (#HR4-025) Aluminium Pulley 23T For R40 (HR4-025) = USD$11.90
1 x 3Racing (#HR4-030) Rear Lower Suspension Mount For R40 (HR4-030) = USD$11.90
1 x 3Racing (#HR4-031) Aluminium Pulley Spacer For R40 (HR4-031) = USD$8.90
1 x 3Racing (#HR4-010) Radio Tray Center Mount For R40 (HR4-010) = USD$12.90
1 x 3Racing (#HR4-006) Front Anti Roll Bar For R40 (HR4-006) = USD$11.50
1 x 3Racing (#HR4-013) Rear Brace RH For R40 (HR4-013) = USD$14.90
1 x 3Racing (#HR4-012) Handle Roll Bar For R40 (HR4-012) = USD$10.90
1 x 3Racing (#HR4-020) Steering Saver For R40 (HR4-020) = USD$12.50
1 x GPM (#HR4037) Alloy Brake Levers For R40 (HR4037) = USD$6.50
1 x 3Racing (#HR4-023) Aluminium Pulley 19T For R40 (HR4-023) = USD$10.50
DuraTrax Pan Head Machine Screw 4mm (20) 1 $3.49
LXDLB4 HPI O-Ring 6x9.5x2mm Black Savage 21 (8) 1 $2.89
LXDLD4 HPI Bevel Gear Set Gear Differential Savage 21 1 $5.79
HPIC2260 HPI Pin 2.5x12mm Savage 21 E-Savage (12) 1 $2.89
LXBPG1 HPI Aluminum Spring Perch Purple (4) 1 $14.79
LXFU76 Sullivan CT-1 Screen Fuel Filter 1 $3.59
LXFRP8 Dubro Nitro Line Yellow 2' 1 $1.99
LXLWT0 DuraTrax 750mAh AAA 1.2V NiMH Cell (4) 2 $5.78
LXKWH9 Integy Super Lightweight Antenna Mount Purple 1 $3.79
HPIC2445 HPI Diff Shaft 6x25mm R40 (2) 1 $5.79
LXFAL3 DuraTrax Slotted Replacement Tip 3.0mm 1 $2.99
Old 04-30-2007, 08:04 PM
  #11468
You dont even want to see my list. Its sickening , at least for me. I can only think about how much money I spent....ha. Heres some stuff off the top of my head.
I know for starters my car was all for LW/stiffness and durability
3racing CF steering plate
3racing cf lower suspension mounts
3racing CF bumper plate (just more secure , actually heavier)
3racing cf battery cover
3racing engine brace
3racing HS engine mount or the hpi hs engine mount
hpi v2 shocks
hpi TI screw kit
hpi CG arms
hpi CG wheel hex
hpi cf side plate
hpi cf lw flex side plate
hpi pro4 purple ti front turnbuckles
hpi rear solid axle (ran at front)
hpi 4 gear rear diff
hpi hara upper chassis
hpi hara super chassis
gpm exhaust mount
gpm ti brake disc
Misc:
acer racing poly bearings
lunsford ti turnbuckles (1-2mm longer than stock)
sanyo 1000mah AAA 5 cell
mugen mtx-3 clutch set w/ grey and yellow pads
lw digital servos
spektrum micro rx
Im sure there is more that im missing. I forget what the car weighed but I was right at legal weight = 1725G. The rest I leave plastic its lighter and the car will perform better. Plus metal likes to bend where as plastic can flex and will move back.
Old 04-30-2007, 08:48 PM
  #11469
CraigM's Avatar
Trader Rating: 34 (100%+)
any idea what the 2005 weighs out of the box? (i know engine/radio gear will affect this)
CraigM is offline
Old 05-04-2007, 04:53 PM
  #11470
stefanos's Avatar
i think its around 1680 with out engine and servos and battery
stefanos is offline
Old 05-06-2007, 06:47 PM
  #11471
CraigM's Avatar
What's the best way to get a spool going up front in an R40?
CraigM is offline
Old 05-06-2007, 07:00 PM
  #11472
I never shared this cheaper option with you guys. Because I never tried it but I have a feeling itll fit the same.
http://cgi.ebay.com/GPM-Alloy-Diff-L...QQcmdZViewItem
If not just get the hpi rear solid diff and you just put it in the front. Solid diffs work well in low-mid traction situations and on tighter / smaller courses. Ive been running a solid for awhile now. I think its a good option and its ZERO maintenance as well it wont change from day to day or if the temperature changes.
Old 05-06-2007, 07:01 PM
  #11473
Heres an even lighter weight option.
http://cgi.ebay.com/Hot-Racing-HPI-S...QQcmdZViewItem
I bought this but never used it and have no idea where it went. I also lost a kawahara 2 speed and some others kawahara goodies for the r40. That really erks me.
Old 05-06-2007, 11:35 PM
  #11474
Rapid Roy's Avatar
Here's a link for the HPI solid axle plug
http://www2.towerhobbies.com/cgi-bin...?&I=LXHLX2&P=7
AI, man that genius finding one for the savage. I think I'm going to have to pick one up.
Old 05-07-2007, 01:49 AM
  #11475
stefanos's Avatar
...now i will add something ,why buy this thing?i mean in my 2003 r40 i just add silicon inside the diferental insted of oil and is solid :P no cost and maybe same weight :P
stefanos is offline
