TRF414M, 404x, 414, 414X
#2236
anyone know where you can get these bulkheads?
http://www.rctech.net/forum/attachme...&postid=346606
how bout the upper/lower deck belt tensioners (square) ?
trf414mII
trf414mII
#2237
Originally posted by TRF-Powered
Hey Izzyracer,
I remember that you did the short wheel base mod to your 04R that you posted in the 04 thread a while back.
Did you have to change the dog-bones for that mod?... did you have to go shorter than 39mm?... Thanks
Hey Izzyracer,
#2238
Originally posted by izzyracer
TRF-powered, No, you do not change anything except the body and the arms :-). The distance from left to right wheel is the same or very close. the distance from the front and back wheel is changed by 10mm. Lots of steering. :-)
Thanks!!!... I was going to do that Mod... I got the arm, just wanna make sure that I don't need anything else.
Thanks Again!
#2239
trf414mII
trf414mII
#2240
414M rally conversion
anyone here tried using the HPI interior rally shell for the 414M? the lower chassis looks identical to the HPI rally kit, i was wondering if it will fit the 414M with minor trimming. anyone tried this? pics would be nice thanks for any info
http://www2.towerhobbies.com/cgi-bin...?&I=LXRT14&P=7
#2241
Hi,
What did he use to polish the outside? I have a spare set of bulkheads and thought about doing the same.
Originally posted by Aurra Sing
Those bulkheads are not for sale. I know the owner... I think he simply polished the outsides of the bulkheads to reveal the silver.
#2242
#2243
Why are the TRF drivers use only the Evo3s in major races nowadays? Is it the end for our 414m2s?
Anybody knows where can i get Eagle aluminum knuckle arms in the web?
#2244
Well, all the TRF drivers use Evo3 to promote the car!!! that's about it. M2 is a very capable car!, it won the world title~!
if you want Eagle stuff, go to
www.integy.com
I think they are the distrubutor for eagle product.
#2246
This is the setup I run all the time at parking lot tracks (sprayed with soda or VHT). It's extremely fast in stock, but I need to work on it for mod.
Front
kick-up: FF - 0.7mm, FR - 0mm
spring: Tamiya yellow or sometimes Associated gold
oil: 50wt.
droop: 2.5mm
uprights: left - C2, right - C1
camber - -1deg
upper link spacer: 0mm
toe: 0deg
Rear
kick-up: FF - 1.7mm, FR - 1mm
spring: Tamiya yellow or sometimes Associated silver
oil: 40wt.
droop: 4mm
camber - -1deg
toe: 2.5deg in
gearing - 120/34 or 124/35 (monster stock)
Lately I have been running the upper links on the shock tower (to simulate Evo3.) More responsive but less grip.
Front
oil: 50wt.
droop: 2.5mm
camber - -1deg
toe: 0deg
Rear
oil: 40wt.
droop: 4mm
camber - -1deg
toe: 2.5deg in
#2247
upper links can you show me how that works
sounds cool
sounds cool
#2248
Front
oil: 50wt.
droop: 2.5mm
camber - -1deg
toe: 0deg
Rear
oil: 40wt.
droop: 4mm
camber - -1deg
toe: 2.5deg in
Front
oil: 50wt.
droop: 2.5mm
camber - -1deg
toe: 0deg
Rear
oil: 40wt.
droop: 4mm
camber - -1deg
toe: 2.5deg in
#2249
I don't have a pic. The inner upper link is just mounted on the shock tower holes like the original Evo3.
FYI - the SSG shock towers don't have these holes.
#2250
trf drivers r using the evo3 because muira who developed the 414 series left to go to hpi and now tamiya seem not to like the 414!lol.its true.ask surikarn he actully said hed profer the 414m to the evo 3 thats y the surikarn edition came out
