Tekin RS ESC sensored
208 ok ive been off the site for a bit im still on 203 has there been any updates since then? i would check the tekin site but at this time it wont let me.
208 is not out yet. From what I gather it's just going to be a spec setting for the new roar stock rules. 203 is still the king daddy for speed.
ah right thanks for that i was going to say i didnt need my 13.5 to be any faster i dont think the thumbs or eyes could keep up on the tiny track we run
Today I tried LRP X12 10.5 with RS. The setup in my RS was still the one I used for 17.5 (boost: 40, turbo:15, start rpm:2300, end rpm:8000). For the first few triggers, I could feel the boost kick in and turbo been activated when full throttle applied. But after about 10 times of triggers, the turbo was gone, it looked like the extra timing from the turbo was spread out into the whole rpm, and the motor became a bit hot just after a minute (120 degree). Because LRP says don't use any advanced timing esc with X12 motors, I thought that was motor's problem. So, I took my X12 out and put Novak 8.5 in, same problem happened again, the boost and turbo worked and then the turbo was gone. Has anyone experienced this kind of problem? Since LRP doesn't like people use other esc with their motor, do you guys use the same setup in your RS when using LRP X12 motors?
HTH
Tekin rs with Losi 17.5
Have been running my rs with EA duo2 (17.5) up till now but thought I would give the losi a try. It was shuddering when pulling away but fine once moving. I did have the same sort of problem with the the EA 17.5 once, but changed the endbell timing and that sorted it, but the losi is not movable. Any suggestions on what the best settings would be for this motor would be great.
This is what it was set at when it started. Sensor lead is all connected ok
FDR 6.5
Timing boost 50
turbo 10
ramp 2.0
start rpm 5000 ish
end rpm 16000 ish
0.2 delay
profile 4
this all works well with the EA 17.5
FDR 6.5
Timing boost 50
turbo 10
ramp 2.0
start rpm 5000 ish
end rpm 16000 ish
0.2 delay
profile 4
Try dropping you timing boost for starters
Do you now what timing is on the can
Are you getting anything from the motor
yeah if you dont know how much timing is on a motor with a non adjustable endbell lower the timing boost
I will say that NONE of the Team Tekin drivers will have to worry about this, none of them should be in the Sportsman classes! LOL
Time to move on with the Tekin info, shall we?!
Correct voltage for 3 amp BEC
It states on the Tekin website that the voltage is 6 volt.. min reads anywhere from 5.69 to 5.75.. is this correct?
My driving has been sportsman like....LOL Going to Norcal this weekend to run some more mod baby
stlnlst, racer-x and i are also driving down to nor-cal sun,,,,,need a ride?
give me a call
rich
give me a call
rich
Losi 17.5
Thanks for the suggestions guys
any idea what the timing on the can is
sounds over timed
sounds over timed
