Tekin RS ESC sensored
did some testing this saturday. put in a x12 8,5 i had here, and it works fine, like a rocket.. put the 5.5 in another friends car with a MMP esc, and it was SLOW...maybe worse than before.. not responding to endbell timing or timing from esc, tried 2 sensor wires, i dit not have any new wires but they have been working fine always before..
i suspect sensorboard??
any idea?
any idea?
ok, thats to bad.. engine is brand new... is it a easy fiks? tried to open and take apart the motor but did not take out the sensorboard..
anyone used the RS for 17.5 boosted 2s WGT ???
need a set up for a race on an indoor medium grip carpet track ???
Thans Phil
Thans Phil
Hi all, i got problem with tekin rs pro esc, run 5 min, before it become slow, like my battery low, but i check the battery, it still got power, sometime 70% 7.9v... I have change the sensor wire and already try other motor, also got same problem, please advice...
We know nothing about what you are doing aside from what speedo you're using and how long till it craps out.
It's likely you have too much timing.
Yup, that's what we all run in my area. Will try to remember to make a screesnshot for you during the weekend. Haven't run it for several months, so I don't quite remember all the details..
We need to know all of your settings in the esc, motor timing, motor brand and wind, battery you're using,etc.
Randy
Last weekend i was running my buggy and it would kogg from a stand still. i changed the sensor wire and ran the buggy last night. it worked fine for one run then started kogging again. i changed the motor thinking the sensor boared went out. ran the buggy again and it started kogging. as long as i'm moving it will not kogg. once the buggy comes to a stop and i start to go it will kogg.
what do you think might be causing this? could the cap be bad?
Looking for setup advice for the following please. Track indoor ozite, medium grip. Approximately 40 x 80 feet. Been to the Tekin website already but didn’t find what I was looking for.
1. 10.5 boosted Touring Car, 2s
2. 10.5 boosted 12th scale, 1s
3. 13.5 boosted WGT, 1s (Tekin website had Cyrul and Dumas setup but without rollout)
Any starting point would be of great help!
Ivan
Ivan
Ivan
Ivan
Throttle profile-----------3------------3
Curent limit-------------off-----------off
Throttle min-------------3------------4
Drag brake--------------10-----------25
Brake strength----------100----------100
Revers speed-----------off-----------off
Neutral width-----------25-----------30
Active brake------------off----------off
Start RPM-------------1496---------893
End RPM--------------7495---------20068
Turbo deley------------.22-----------.26
Ramp------------------2-------------2
Boost-----------------48------------45
turbo-----------------10------------10
Endbell----------------0-------------0
Rollout----------------65------------70
The 1/12th 10.5 is what I was running outdoor on a larger track and I have not had a chance to try it on the carpet yet. I do not run 10.5 boosted touring so I can not help out there. The WGT is also my outdoor setup but I put it on the carpet for some laps and it worked quite well.
I am still tuning these settings but I hope this will get you started.
Neil.
------------------------WGT--------1/12th 10.5
Neil.
Neil.
You guys on the Island have the experience in these classes so that's definitely a good starting point. The first WCICS race is next weekend in Edmonton so hope to get them tested before the race.
Now looking for 10.5 Boosted TC as my last year's boosted 13.5 is gonna get killed down the straight!
Ivan
Hey guys. Can anyone please help me with a setup?
Xray T3 (T4 next week)
Rs Pro
17.5 Fantom Ion 4
The track ill be racing on is at Logan in QLD Australia.
Thanks in advance for any suggestions.
Rs Pro
17.5 Fantom Ion 4
Rotor: 12.5mm (standard)
Endbell Timing: 12 (factory default)
Gearing: 7.2
Battery: orca 6500mAh 70C
Throttle profile: 3
Curent limit: off
Throttle min: max
Drag brake: off
Brake strength: 90
Revers speed: off
Neutral width: off
Active brake: 10
Start RPM: 6000
End RPM: 25000
Turbo delay: 0.08
Ramp: 2
Boost: 50
Turbo: 15
where can i buy a sensorboard for tekin redline? and is there a guide on how to change it?
