Tekin RS ESC sensored
Hi Guys,
My question is this, can the brownout problem be resolved with the use of a cap connected to the reciver?
I ask, because, back in the brushed days, I would have laps missed when racing modified on carpet with foam. We eventually worked out that because the scoring loop was located on a corner exit where the car was accelerating, that the current draw from the motor was causing the transponder (and probably the Rx and servo) to lose power. I solved the problem by connecting a 4400uf cap to my reciver.
Mark
Mark
Yes it may cure the problem. Again this has nothing to do with the ESC but more related to the higher power demands of these new servos especially Savox.
BTW it is not the ESC that browns out but rather the receiver. So when the receiver goes down the ESC loses the radio connection and can't find a signal. With 2.4GHz radios and the handshake protocols it takes a few milliseconds for the receiver to establish contact with the transmitter. This seems to be less of a problem with FHSS protocols.
The cap did not resolve my brownout problem, however I think the castle bec may, I wiould consider buying it for $20.00 before the cap.
would running a receiver pack fix the brown out problem?
is everyone having the brown out problem using tekin/spektrum/savox setup or is it hit or miss?
Spektrum and Savox seems to be the worst combo. Why people keep using Spektrum stuff is beyond me. Seriously people, there are MUCH better performing radios out there. Also, I have seen brown outs with the Spektrum/Savox combo on some other speedos too.
If you're having brown-outs, it's worthwhile to open up the RS case and inspect the receiver lead carefully. I've replaced the lead on more than one that was kinked and slightly melted enough to knock you down to just a few strands of wire trying to do all the work.
If you change leads to a larger gauge wire, a little bit of work on the case to open up the hole, and a little patience sliding the wires through the rubber grommet make for a robust fix.
The worst one of mine was browning out and acting weird even with a CC BEC. Once I replaced the lead, it was back 100%, no RX cap, no external BEC required.
1s to 2s troubles
Have an rs that I've only used in 12th scale blinky since the fall, was using a tq booster. Anyway, I've decided to use the speedo in a new touring car to try a little boosted running and, I cannot seem to get any power to my receiver. Hotwire reads the speed control, battery is charged and I got nothing when I turned the speedo on. Tried bypassing the switch and a different reciever, still nothing. Any ideas of what the problem may be?
Thanks, Eric Lee
Thanks, Eric Lee
Ya true enough fortunately most people have ran a castle product and have the progammer or no someone that does, but not a given.
Thanks, Eric Lee
Thanks, Eric Lee
is 222 out?
tekin rs no cap
hey guys i bought a used rs on here i did not notice it when i bought it but now i notice their is no cap on it and probably never has i was able to install the updated software and adjust the settings on it is this a big deal,and can i used a cap that has the same voltage ,but a higher uf rating so i dont have to buy one
The "minor tweaks" are a bonus. 222 was pulled because they left sensorless operation disabled, as well as some people complaining about weak brakes in boosted. Thus, if your sensor wire or sensor board became damaged, the motor wouldn't work at all.
download
i just downloaded it do i need to download it again now i quess
