battery numbers
#31
Originally posted by Randman
From what I have learned, the only packs that you can trust 100% are the ones matched on a turbomatcher. You can't change any of the variables on the turbomatcher to make the #'s seem any higher than they actually are. I am sending all of my packs in to Fukuyama to be rematched on a turbomatcher to make sure all of the #'s are accurate.
Let me know if you want yours re-conditioned or just purely re-matched.
Dan
#32
Originally posted by Grizzbob
Actually, I don't see a problem in seeing numbers based on charging at 6 amps, since many of us are charging them at that rate anyway(like I do). And from what I hear, ProMatch is seeing voltage numbers just as high as SMC, & they charge at 5 amps for their testing, so I really don't think it's an issue.....
Dan
#33
my newest pack has 1.189 vilts and 536 run time i got them off the guy who owns the company for 30 $
#34
#36
Danny at SMC did a comparison of the same cells, matched at 6 amps, then 5. The numbers were virtually identical, the difference was in the IR. I beleive the results are on Hobbytalk -->general--> SMC wants your advice
#37
God you guys are stupid.
#38
#39
fukuyama
does fukuyama sell batteries or just rematch batteries??
#40
Consider this:
Take a look at the BEST packs from one to two years ago.
Matched at 5 amp charge and 20 amp discharge.
Compare to 6 amp charge and 30 amp discharge.
When you see the kind of run time and voltage characteristics of the new breed of "Supercells", really consider what you are seeing.
I remember AWESOME 2400's that at 30 amps were only showing voltage of 1.100 per cell. and that was under 400 seconds.
Don't tell me that a 6 amp charge is going to scew the nubmers that much.
#41
Re: fukuyama
