Old 08-13-2003, 02:19 AM   #1
TWiZTiD's Avatar
Default removing color from alloy
can some one tell me a easy way to remove color with sanding the part
TWiZTiD is offline   Reply With Quote
Old 08-13-2003, 03:16 AM   #2
JohnA's Avatar
'easy off' oven cleaner works geat, just dont leave the parts in too long. About 5 minutes should do the trick.
JohnA is offline   Reply With Quote
Old 08-13-2003, 03:56 AM   #3
TWiZTiD's Avatar
easy off brand ?? cause the stuff i got dont work
Old 08-13-2003, 10:06 AM   #4
rc-zombies's Avatar
Yes... Easy OFF oven cleaner... it will work faster if you put the parts in the oven at 300deg. for about 5min. then spray the oven cleaner on it.
Old 08-13-2003, 10:20 AM   #5
Randy Caster's Avatar
Trader Rating: 46 (100%+)
There are actual anodizing stripper solvents, the problem with EZ off is after it takes off the anodizing, it will begin to attack the aluminum, leaving pits and a crappy surface. The anodizing stripper only attacks the anodized layer, and doesn't harm the aluminum after the anodizing is gone. You can find the stripper on this site http://www.caswellplating.com/ Good Luck
Old 08-13-2003, 10:27 AM   #6
corvettecrazy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to corvettecrazy
supposidly nail polish remover will also remove anodization.
corvettecrazy is offline   Reply With Quote
Old 08-13-2003, 10:30 AM   #7
I tried it and it didn't work for me...
Old 08-13-2003, 10:38 AM   #8
rc-zombies's Avatar
I just checked out Caswell plating... I may have to buy my own Anodizing kit... not bad price for a small kit... only $200.00
Now I can do my own orange parts..
Old 08-13-2003, 10:50 AM   #9
That isn't everything though, you need a power supply to get the current, and a few other things. I thought about it a little while ago, that's why I have the link, but it is too much of a hassle. If you want to learn some more about anodizing, this is the site http://www.focuser.com/atm/anodize/anodize99.html
Old 08-13-2003, 10:55 AM   #10
rc-zombies's Avatar
Yea...you're right...it is alot of hassle..
Old 08-13-2003, 11:22 AM   #11
Old 08-13-2003, 11:23 AM   #12
CGR
CGR's Avatar
Bead Blaster
CGR is offline   Reply With Quote
Old 08-13-2003, 11:27 AM   #13
Not many people have a bead blaster though...
RC-Zombies - DynoMan on this site does anodizing. That isn't his full username, has some digits on the back, but check him out in the paint forum.
Old 08-13-2003, 11:35 AM   #14
rc-zombies's Avatar
I've already contact DynoMan...he can do Orange
Old 08-13-2003, 11:37 AM   #15
You should send him a few parts off the Web Special to make sure it's a good match...
[B][COLOR="Black"][SIZE="5"]GO TECH ENGINES what are your opinons?[/SIZE][/COLOR][/B] Crazy Carl Nitro Off-Road 5 02-27-2008 02:58 PM
WTB alloy screws and alloy/titanium parts. muvro Australia Wanted to Buy 0 05-09-2006 06:12 AM
[COLOR=blue]Brand New Calandra 1/12 Rc Car With Ko Propo Digital Servo [/COLOR] [email protected] Malaysian R/C Racers 1 08-29-2004 11:16 AM
Removing anodized color? j240z Nitro On-Road 13 05-27-2004 07:27 PM
Removing CA Calvin Ng Electric On-Road 1 08-03-2003 11:54 PM
