Associated RC12R5
#2671
Trader Rating: 50 (100%+)
Thank you for your response ....... perhaps I should mention these are not the R12 Hubs, although the Hubs used by Masami in his Yokomo 12R5.
Any help would be appreciated.
#2672
Yokomo back in stock !
#2673
#2674
PM sent looking for yokomo part no. http://www.teamyokomo.com/jpn/partsl..._sp_4608s.html
#2675
Question???? is the Yokomo wheel hole pattern similar to CRC, Jaco,Parma???
If so then I see no reason why I could not use them to provide me with a shorter wheel width. Would you not agree
Thanks Again !!!
Alex
Thanks Again !!!
Alex
#2679
They're not the long hubs for the more positive offset Yokomo wheels, which he might have mistaken for.
#2680
Kind Regards!!!
Alex
#2681
No need for Japan.....
http://www.driftspeed.com/index.php?...006665e2f846e8
They are here in California.
#2683
The Yokomo Part No. SP4608S is the complete Left & Right Hubs in addition to the Thrust Cone as pictured below.
Thank you to everyone who has responded!!!!
Alex
#2684
I've just built a new RC12R5.1, so I have the standard weight oil in the centre and side shock (30wt and 20wt). I have a spare centre shock and side shock and wanted to build them up with different weight oils as a quick tuning option. I will be racing mainly on tarmac with mild modifieds (10.5, 6.5). What weight oil should I put in each of them, any suggestions?
#2685
I run anywhere from 20 -40 in the side shock and 30-50 in the center shock.
Hope this gives you some ranges to try.
Mike
Mike
