GT10 Class
#136
Back in the day purple fronts and pink rears worked everywhere on asphalt and Purple fronts and white rears were the ticket on carpet.
In testing we have been running Pink or Double Pink Rears and Double Pink fronts on carpet and asphalt. This is the modern tire combo also used on 1/12th cars on any surface when running Mod or 10.5.
If we were running stock or 17.5 we would have changed to a lower bite rear tires on carpet like white.
I'm sure you have connections Adrian... See what you can do!
#137
I for one just dont want this to be one of those have vs have not classes where you have guys with all sorts of tires and changing compounds and what not. I dont think that it should be a "handout spec tire" in that sense, but having a tire that everybody runs (if for no other reason than it works). This would keep costs down because unless they are doing something wrong, somebody isnt going to use up a set of tires in one race day.
I also would love it if a company like Jaco were able to make tires based on the new Prizm rims for 1/10 pan.
#138
Take a look at 1/12th scale and you've got an overwhelming majority of racers using the same compound as other racers in their class. So, it will just take a little while for certain compounds to be the compound of choice on a given surface. It's not like TC where a certain rubber tire is a little faster but might wear many times faster as well. Also, I don't think 1 run foams will be an issue like it can be in TC since it's overwhlmingly not the case in 1/12th.
#142
I wouldn't say there is hype about it. If you read the first page, you'll understand that we are trying to develop new rules for the new 200mm cars that are coming out. So this is just a discussion of what those rues should be. And what we will try out when the cars "do" hit the market. Once people try it out. Then maybe we can finalize the rule set with everyone's input. Then if tracks want to look for a guideline or rules to go by, we'll have our rules out for them to try.
Hope that makes sense.
Oh, and please don't think I'm the one running the show just because I started the thread. I'm just trying to get a discussion goin and trying to formulate rules from that. So far the only "real" input we have are from those that have run the prototypes...
Body rules is gonna be the hard one...
#143
I am told after talking with:
Bryan Norris
Customer Service/Technical Dept
KYOSHO AMERICA
20322 Valencia Cir
Lake Forest, CA 92630-8158
That they are eather on there way and can be ordered now.
#146
People will gravitate to the typical race cars in a GT series anyways, except for some guy that drives a car that that has an RC body available. Why not make him happy and let him run whatever car he drives as long as it's a coupe.
Or, you could do the right thing and only allow Honda Odyssey bodies
#147
This class looks very promising... I agree that we've had enough touring bodies already, time for the GTs to kick in!
We are starting to organize a GT-like class here but the ticket for us is finding a nice, inexpensive platform, otherwise would be newcomers get scared about the costs. So far we want to use low cost tourers as both GT and rally platforms (just change tires, bodies, adjust ride height and go)
However, your approach to using 1/10 pan cars is interesting... what's the advantage of using those instead of a low end touring chassis? (say tamiya or hpi sprint for example)...
I love the way the BMI DB10R looks (must be extremely light) but how much do these go for? what other brands are you looking at?
#148
You can make things easy and just allow any 2 door coupe. If you limit it to cars that are technically considered a GT there won't be many shells to choose from. If you limit it to only bodies that race in GT series then you're going to have almost as many choices as if you just allow all coupes and leave out a couple cars that are more or a GT car than many that you're including. The Soarer would be an example of this, it's a very traditional GT car.
