Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 01-26-2008, 11:15 PM
  #6061
wallyedmonds's Avatar
Originally Posted by ScionBox
Excellent write-up on the Speed Passion!
I have made up my mind and will jump into brushless with the Mini. The variance in RPMs from one black can to another is irritating.
Now I just have to decide between the Speed Passion and the Novak.
im thinking novak
i got a 007 sphere in the mo3r now so its just a motor change for me.
dont trust speed passion,but thats just me.
wallyedmonds is offline
Old 01-26-2008, 11:33 PM
  #6062
Herkimer Jitney's Avatar
Originally Posted by tony gray
Is there an alternative to the trusty Silver Can and Sport-Tuned?
You bet there is...
Click here to check out the full story
Love that write-up dude. Youve got me convinced I think. I think there are some local guys here that run the Speedpassion setup too sounds like its good. Novak stuff costs a fortune here.
Herkimer Jitney is offline
Old 01-26-2008, 11:52 PM
  #6063
ScionBox's Avatar
Originally Posted by wallyedmonds
im thinking novak
I have decided on the Novak XBR 13.5 motor/ESC system. I've read a lot of good things about them after doing a little research on the web tonight.
ScionBox is offline
Old 01-27-2008, 01:10 AM
  #6064
Xtant3150c's Avatar
Originally Posted by Xtant3150c
Hey Tony (or anyone else who might know) would you happen to know what the amp draw is of a Silver can motor (and possibly the Black Can) in an M03?
Mahalo's for any help.
Anyone?
Nice write up on the Speed Passion Brushless! Hopefully our Mini Class will jump into the 21st century One Day
Xtant3150c is offline
Old 01-27-2008, 01:12 AM
  #6065
tony gray's Avatar
No idea..it's not something I've ever needed to check!
tony gray is offline
Old 01-27-2008, 02:06 AM
  #6066
razzor's Avatar
The Exige system from SpeedPassion might be entry level but boy is a lot of fun in a Mini
I used it a little in various cars and over the last 3 months then loan it to a few club guys and freinds to try out.
Everyone loved it and only complaint from the Mini guys was there tyres where not lasting as long as they used too
I sponsored a system for a Drift competition and the winner fitted it in to a ABC genetic chassis and its awesome.
My gripe is you need the optional programmer for the throttle profile since the car hesitates a bit as it gets going and then its like it hits 2 bar boost but only if you plant the throttle.If you smooth with the throttle it accelerates well with out a issue, looks like a launch control of sorts on std setting.
For the price they awesome value.
razzor is offline
Old 01-27-2008, 02:15 AM
  #6067
Xtant3150c's Avatar
ThanX Tony for the help.
I was just wondering as Castle Creations has a firmware update for the Mamba 25 to allow it to run brushed motors! I am currently trying this out in my Crawler with a 55t lathe motor and it has been working so good in the limited time I have been running it.
Been thinking about trying it out with a Silver can setup in my Mini.
Another question I have is what is the amp output on the Speed Passions esc? Can't find any info on that.
Old 01-27-2008, 02:35 AM
  #6068
tony gray's Avatar
I got ESC specs but nuthin on the motor...
ESC is
Specifications:
Input Voltage: 6v~14.8v
NiCd/NiMH 5-12 CELL (6v-14.4v)
Li-polymer 2-5 cell (7.4-14.8v)
Continuous current: 40A
Max Current: 120A (10sec)
BEC: 5v/2A
Drive Frequency: 8Khz
Dimensions: 40(L) x 28(W) x 13(H) mm
Weight 44g
Recomended motor limit: 13.5T and over sensored or sensor-less brushless motor.
Old 01-27-2008, 02:44 AM
  #6069
razzor's Avatar
the Sport tuned JR SP motor is a 3000kv, the Sport tuned Pro SP motor is 3300kv.
razzor is offline
Old 01-27-2008, 03:26 PM
  #6070
I showed your review to a few of my buddies and I think were all going to get them now. Funny name but look like cool speedies and motors.
Old 01-27-2008, 04:11 PM
  #6071
Mike Schumacher's Avatar
Trader Rating: 37 (100%+)
Is bump steer a common problem on Tamiya M03?
Mike Schumacher is offline
Old 01-27-2008, 07:39 PM
  #6072
tony gray's Avatar
If your suspension is set-up correctly bump steer shouldn't be an issue at all.
A well set-up Mini will only use a few mm of travel, and over that sort of distance bump steer is virtually non-existent anyway.
It only looks bad when you're holding the car in your hand and moving the arms up and down. On the track it has virtually no effect.
Old 01-27-2008, 09:54 PM
  #6073
maskedrider's Avatar
Hi Guys,
I just fixed in Tamiya sport tune motor ( Black cans ) on my MO3M.
Question is do i need to lube/oil into this motor or just run as its is.
thanks for the advised.
Cheers
maskedrider is offline
Old 01-27-2008, 11:52 PM
  #6074
razzor's Avatar
always a good idea to lube the motor bushes with bushing oil or 0w30 motor oil.
razzor is offline
Old 01-28-2008, 12:58 AM
  #6075
TryHard's Avatar
Hey guys, took my MO3R out this weekend for a bit of fun... and unfortuantly ended up breaking the top off one of the blue shocks
TBH, I don't care much for plastic shocks, I've had endless problems with trying to get them apart to change the settings. The tops are just incredibly stiff, and mean I have had to use two sets of pliers to get them undone... not good. IMO, TRF shocks, whilst a little more expensive, are certainly the best way to go... if only from a maintence point of view if not on track performance.
Still breaking the shock gave me an excuse to finally fit my spare set of TRF's from my tourer to my mini, and I realised in that in fact they really aren't that much longer overall in comparison to the mini CVA's anyway. The body may be longer, but the top is shorter, so overall length is very similar.
Also took the opportunity to mount my electronics in the chassis, managed to fit the Tamiya ESC into the rear halves, and my KO 302 reciever into the front part, right behind the chassis. Set it up so that to change the crystal all I have to do is undo the 4 screws holding the front and rear together. I'll post some pics later if anyone is interested.
Looking forward to getting the Mini back on track this weekend... was a massive improvement last time out, and I've made some more changes, so itching to try it again... almost tempted to run it in the 27t class against the 4wd's to just see how it goes
Regards
Ed
TryHard is offline
