Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 01-29-2008, 11:38 PM
  #6091
Originally Posted by doriftu
this may be a dumb question: are those 2 racing stripes on the hood decals or spray painted?
btw Kreator nice paint job. speck and clean.
My guess would be sprayed...
Ben.C is offline
Old 01-29-2008, 11:53 PM
  #6092
KREATOR1's Avatar
Thanks bro, those stripes are original decals from the box.
KREATOR1 is offline
Old 01-30-2008, 05:34 AM
  #6093
ChuckWick357's Avatar
Here is my new Lid.
Attached Thumbnails Tamiya mini cooper-mini1.jpg   Tamiya mini cooper-mini2.jpg   Tamiya mini cooper-mini3.jpg   Tamiya mini cooper-mini4.jpg
ChuckWick357 is offline
Old 01-30-2008, 07:51 AM
  #6094
Hey, do you guys have issues with the tires rubbing the body?
I have two points that rub; In front of rear tire and just under the edge of the front bumper. I can fix the front by limiting the EPA (too much steering when racing is bad anyway) ; however the rear tire is an issue, I am thinking about using my dremel to cut down the lower arm and shim it backwards into the middle of the wheel well what do you guys do?
Old 01-30-2008, 08:08 AM
  #6095
slammin's Avatar
Trader Rating: 88 (100%+)
I use the traxxas body washer to lift up the body.Its just enough to keep the tires rubbing in the back.
slammin is offline
Old 01-30-2008, 08:18 AM
  #6096
Do you put them on the front post of the rear? As you can see in the Pics above if a lift the rear of the body the angle would push the body closer to the wheel. Lifting the front up would help but the car looks like crap with a negative rake.
Old 01-30-2008, 08:27 AM
  #6097
slammin's Avatar
I use them on the front and rear.
slammin is offline
Old 01-30-2008, 10:15 AM
  #6098
minimanintaiwan's Avatar
Originally Posted by Zubski
Hey,
I have a question about the silvercan motor.
I have entered the FastCats Mini Enduro, 1000 Laps. Can the motor last that long or will it need cooling and if so what type of cooling? Do you have any advice on running a race that long.
THANK-YOU!
Patrick Z
You're using the stock heat sink already right?
#53344
try this fan,
http://www.rcmart.com/catalog/produc...ducts_id=22395
or this heat sink,
http://www.rcmart.com/catalog/produc...ducts_id=25702
U can also try a can of compressed air. The ones to clean computers and electronics that usually come with a thin straw nozzle. Turn the can upside down and spray, it will shoot out the compressing gas which is freezing cold. I used it right in the cooling ports of the motors and on the heat sinks. Cools it right down fast!
Attached Thumbnails Tamiya mini cooper-yrac_ya-0168bu_001.jpg   Tamiya mini cooper-3rac_m03m-09-lb-_001.jpg
minimanintaiwan is offline
Old 01-30-2008, 10:58 AM
  #6099
Zubski's Avatar
#53344
try this fan,
or this heat sink,
Thanks for the advice. Actully i am not useing a heat sink right now but we are planning on putting one on for the race. How much compressed air would it take to cool the motor right down? Does it take a bottol just for one pit stop?
Zubski is offline
Old 01-30-2008, 02:18 PM
  #6100
Turbonium's Avatar
Trader Rating: 27 (100%+)
not sure id reccomend the ice spray trick on a hot motor... a buddy many years ago did this with a very hot P2k2, and the result was one of the magnets came loose, due to the rapid change in temps between the dissimilar metals... fyi, anyway!
Turbonium is offline
Old 01-30-2008, 02:42 PM
  #6101
R/C Tech Elite Member
abailey21's Avatar
Trader Rating: 37 (100%+)
I'm going to be probably the 100th person to ask the same question, but here goes.
Why hasn't Tamiya updated their rules to either;
A: Allow brushless in the TCS series
B: At least use a more updated motor than the closed endbell Willy?
I ask this because I'm really interested in the M03 platform but the electronics restrictions are killing me
Is it because of the "value" price point?
Is it because the "heart" of the M03 is spec racing?
I ask this meaning no malice and disrespect, I'm still going to get one regardless of what the rule "are" or "change" to.
I was just kind of wondering, cause I am a fan of spec racing more than anything and the concept is awesome.
abailey21 is offline
Old 01-30-2008, 03:26 PM
  #6102
Wicked-Wayz's Avatar
Trader Rating: 19 (100%+)
A. They do allow brushless in the tcs now.
B. Not sure I understand what you mean.
The mini is set basically to be the true heart of spec racing. This is also because of the value as well I am assuming.
Peace Aaron(W-W)
Wicked-Wayz is offline
Old 01-30-2008, 07:25 PM
  #6103
abailey21's Avatar
That's the answer I was really hoping to see. I love spec (grew up on it) but it seems it hard to keep the fun in it. I love the mini because the rules are set to make sure the fun is kept within the track and racers.
Peace Aaron(W-W)
Old 01-30-2008, 07:26 PM
  #6104
abailey21's Avatar
  #6105
abailey21's Avatar
