Tamiya mini cooper
#2776
Umm, they dont exist as an official part....
So I think that sort of answers that question.
#2778
Originally Posted by GreaseMonkey
Is there any way you can get an M04 chassis down to a short wheel base? My main issue is that there's very few RWD bodies available in the 225mm wheel base so if I can shorten it. I won't have to worry so much about getting new bodies when the time comes.
#2779
The HPI Honda S2000 is for 190mm chassis. They have a Civic body for the M03 chassis.
#2781
Originally Posted by tony gray
Or....dont use any at all.
We're having a lot of success with the 'no-limiter' setup with massive droop allowable. Just use the spring and the adjusters to set the ride height but let it all hang down...
Not entirely sure what the theory behind it is, but it works.
#2782
If you're trying that many different settings then you're over complicating things.
Its either a single spacer (equiv to 3 o-rings) or none at all. Doesnt matter which shock you're using really.
The 'no o-ring' setup doesnt work everywhere, or for everyone, but its certainly a legitimate set-up and worth trying.
#2783
)))))))))))00000000000 rings
I will try it at the novak people will be traction rolling every where I have a extra set of shocks i willl build them and try em with no 0 rings but I bet with the traction it will not be the way I won last year with rings but who knows btw Happy new year to all U mini Drivers!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
#2784
The mega droop setting seems to work well for low to medium grip tracks but requires a smooth racing line, it doesnt seem to work as well for more aggressive style driving.
We have also had a lot of success with no droop, and really hard springs (22-24lbs) it really makes the front tyres work very hard.
We dont run on carpet here unfortunately and none of our tracks are really high grip so it will be fairly different on carpet I would say.
Also one thing I tend to run and seems to work for me is about 1mm ride height, I have found that the chassis doesnt realy scrape very much at all and with the lowered ride height you get more camber on the front wheels which seems to give it much more steering. Makes it great in the tight twisty sections.
tp
tp
#2785
Hi all
Im new to the rc mini thing and would like to know were you all get your parts from? (Im in Sydney and going to race at Windsor)
I also like the sports sedan race body and would like to know how to get my hands on one.
Glenn
Glenn
#2786
Hi Glenn,
Sydney has a lot of shops where you can get Tamiya stuff and other related Mini gear (Check out Racing Lines Mag for some addresses etc) but I'd be lying if I said that our stuff was purchased locally.
We get most of our mini gear from Rainbow Ten , rc-champ ([email protected]) or rc-mart . It just depends who's got what we want at the time.
The Sports Sedan body? I assume you're talking about the Chevron Monster M body. Sadly no-one has them at the moment. They're rather hard to come by.
#2787
Originally Posted by zipper
Hi all
Glenn
Glenn
#2789
guys what are the advantages of using large tires like the one using in touring cars compare to the small tires for m03's...
#2790
The ABC Nissan Sunny (Datsun 1200 for Aussies) Truck has arrived. And its absolutely BRILLIANT!
Check it out now at our site.
