Like Tree86Likes
Hpi Pro 4
Old 07-06-2004, 03:23 PM
  #6031
c1 racin's Avatar
Originally posted by xxxkat
c1,you dont need to hop up anything..well maybe the gear brace for the front oneway, but thats all you really need.
Can you give the part number?
thanks for your help
c1 racin is offline
Old 07-06-2004, 06:41 PM
  #6032
How often do you guys clean your bearings? What do you do to clean them?
Cheers,
Mossie
Mossie is offline
Old 07-06-2004, 06:50 PM
  #6033
DOMOisCOOL's Avatar
Cheers,
Mossie
I clean them after every race(neat freak) and I spray some motor spray on it then use some LIGHT oil.
DOMOisCOOL is offline
Old 07-06-2004, 08:49 PM
  #6034
thanks man, how do you clean them? I havent cleaned mine yet and ive been driving my car for 5 months
Cheers,
Mossie
Mossie is offline
Old 07-06-2004, 10:29 PM
  #6035
rod_b's Avatar
RPM make a tool (bearing blaster I think it's called) that you can sit the bearing in and shoot motor spray into and it will blow the dirt out. I use a tool from Integy called the Indi Sparkle Parts cleaner. It's powered by 2 AA batts and it basically vibrates to shake dirt out of the bearings. Works pretty good.
rod_b is offline
Old 07-06-2004, 10:38 PM
  #6036
Oasis's Avatar
Trader Rating: 38 (100%+)
Cool,Where do you get them at..and how much..The bearing cleaner
Oasis is offline
Old 07-07-2004, 12:16 AM
  #6037
DOMOisCOOL's Avatar
Yeah, basically, it's a jewelry cleaner.
Old 07-07-2004, 12:54 AM
  #6038
Speedtech has the Intergy bearing cleaner....works good
Barger is offline
Old 07-07-2004, 02:34 PM
  #6039
Guys,
I need your point of view, I plan to buy some ceramic ball bearings for the Pro4
Do you think it is worth buying them as the price is rather expensive...
thanks for your input
Ralf is offline
Old 07-07-2004, 02:36 PM
  #6040
rc-zombies's Avatar
Originally posted by Ralf
Guys,
I find the stock one to be very friction free already...
if you're racing competatively then it may be worth the extra money.
rc-zombies is offline
Old 07-07-2004, 02:46 PM
  #6041
DOMOisCOOL's Avatar
The stock ones are pretty good already. Just make sure you clean them frequently to keep them rolling smoothly.
Old 07-07-2004, 02:58 PM
  #6042
DOMOisCOOL's Avatar
Hey guys, I wrecked last night after a few tumbles with the car and then smack right onto the boards.
The aftermath:
The "potential" fix:
I know it's a bit off center but it's just a prototype. I had an old Kyosho V One R that I sold about a year ago. And I kept the Lola Body Bumper set. Took the bumper and trimmed it a bit. Then drilled two holes big enough to fit the body post base. I'll let you guys know how it does this Sunday.
Old 07-07-2004, 06:50 PM
  #6043
Tek Nickal's Avatar
Dude, are you sure that thing won't poke the other cars? Cut the ends off man!
Tek Nickal is offline
Old 07-07-2004, 06:54 PM
  #6044
DOMOisCOOL's Avatar
It fits under the body perfectly.
Old 07-07-2004, 07:29 PM
  #6045
Pit-racer's Avatar
I just went thru my pro4 and rebuild it. Do you guys have trouble w/ the e-clip that goes on the spur retainer? Does it cause the spur to be off center as it spins?(wobble a bit)
Pit-racer is offline
