SpeedMerchant Rev 5
#499
that is a speedmerchant conversion for the associated 12r5 no idea if it will be a production car.
#500
Donny Lia
You have a PM!
You have a PM!
#502
you can, but the old wheel have always been a problem no matter what front end you used. you have to be friends with a dremel and work the ball cups and also the shimming is critical. I also found removing the color dot for the compound
#503
02/16/2007 Hi Guys. I get a lot of e-mails asking how we off-set the JACO front rims to give our 4.5's a wider stance for high traction conditions. It's actually pretty easy with the proper tool. We use an American Standard prop reamer. They are available thru Tower Hobbies, and are under $15.00. Here's a direct link. Prop Reamer
Have a great day.-Bruce
If not we have been running our rev5's with prism wheels shimmed out for a while now. Sounds like a similar situation, we simply run the nut backwards so that the nylon locking part of the nut goes inward toward the car instead of out.
#504
hey man, whats up
#505
Wheels and tyres for the rev5
Due to take delivery of a couple of rev5s in the next week or so. Due to go too the Snowbirds in 2010 for the first time. Never raced on a Usa rug. Looking for tyre advice .
What you guys running on the Snowbird type carpet. Also as regards handling what sizes front/rear rubber. TIA
#506
R/C Tech Elite Member
#507
what class
Hope to enter 10.5 and need to choose between open mod or 17.5. Never ran 17.5 before so would need to buy one.
Also need to look at timings to see if i could manage all 3, dont know how hectic that will be.
Will have 2 cars kitted up.
#508
The link is dead, but find a standard prop reamer. I believe it was only the outside one you needed to ream. I always had Bruce do it for me back then, but you ran the standard flanged bearing inside and an unflanged outside. So I think you only need to do the outside to seat the unflanged bearing.
Hanulec the man!! Whats up? See you Saturday
