Tamiya DB01
Old 09-13-2007, 05:57 AM
academygaz's Avatar
Default Tamiya DB01
Found on another forum:
DB01 [durga] December 1st sale estimate value \ 22,800
They are 2 belt drive Brin new off road chassis which succeed the gene of TRF501X. In order to guarantee high dustproof characteristic and maintainability, drive system guarded with the resin make cover, the chassis unified the front and back bulkhead and decreased part constitution and raised maintenance characteristic. Of course, the suspension arm provided the abundant setting point with the same form as TRF501X, (CVA damper equipment). As for the body the racing like design which makes TRF501X REPRESENT. The motor does not belong.
academygaz is offline
Old 09-13-2007, 07:16 AM
SQC049's Avatar
Trader Rating: 18 (95%+)
Looks like a XXX4
SQC049 is offline
Old 09-13-2007, 09:16 AM
jarkkom's Avatar
That pic is so manipulated... But theres a new low end 4wd car coming indeed.
jarkkom is offline
Old 09-13-2007, 05:33 PM
jobo_ph's Avatar
Trader Rating: 11 (100%+)
Yeah it looks manipulated... TA05(?) + TRF-501X + graphics editing (drivetrain cover, color changes)
jobo_ph is offline
Old 09-13-2007, 05:36 PM
Suspended
atleast tamiya still makes those connectors........
hated1racing is offline
Old 09-14-2007, 12:16 AM
bender's Avatar
Here are the real pics( (see attachments):
It is basically a budget version of the 501, using the 501 suspension with a Ta05 style chassis which allows you to use stick packs.
Whilst it would cost a fortune to convert to a full 501x, I can see some advantages in this car, especially if you aren't interested in running saddle-pack cells.
The body looks better to me, plus there's no undertray to wear out, and obviously the drive train is much better protected (though much less accessible).
bender is offline
Old 09-14-2007, 03:50 AM
stickman310's Avatar
Yeah tamiya connectors are great! You only have to change them about one every 2 uses because they break and melt! Awesome!
stickman310 is offline
