Tamiya TRF416 / TRF416WE / TRF416X
#1351
Yeah, I'm waiting on the SpeedPassion 17.5 to come out. Then I'll try 17.5. That or wait for Tag to label up some 17.5 motors. You running at Mimi's or Debbies? I need to head back up that way sometime again. I don't get to run rubber tire carpet much. I think this was the first year I've actually race it in a class. I have a lot to learn about rubber/carpet. I mostly do asphalt.
#1352
JimmyMac come on back upon the 23ed for the SMC race
at Mimi's to run some more carpet rubber
#1353
#1354
I was able to run a 98 spur and 46 pinion....that about a 4.3 for 13.5, with a smaller spur gear(88/82) it will push the motor back to get maybe a bigger pinion gear in. or 88/46=3.92
Todd if you need a set up for the Race for the TCS race LMK. I think I have something that will get your car to respond well. I am still working on somethng to attend the race. I will be selling the TRF416 after that race.......
Todd don't forget about the Carolina Classics.....It would be nice to have you come down and race. There is also a Durham track by my house that we can test your skillz!
What Body did you race at Trackside?.....I will be running a Bimmer on the 416 with a the NSX for back up just in case the crowd start rolling fast.
#1355
EDIT POST
#1356
WHY!
#1357
Let me know when the next big race is up there. I'll try and attend that.
#1358
Hey guys,
I'm literally in the middle of my build for my new 416. I've got a couple issues. First off, I've noticed what seems to be an excessive amount of play with the spur gear/center pulley assembly from left to right. The manual says to use one of the 0.2mm washers on each side of the bearings, but is anyone using more to try and get rid of the back-and-forth slop? Also, just looking at the assembly, it seems like the pinion has to stick out an excessive amount in order to mesh in the center of the spur gear. Has anyone else noticed this, or am I just building this thing wrong?
I've never owned a Tamiya car (AE, Yokomo, Xray in the past), and so far I'm very impressed with the fit and finish, but the way the parts are arranged and the clumsy instruction manual leave much to be desired.
Thanks everyone.... cant wait to try this thing out.
#1359
Shim the center pulley to where you feel it is right for you. The kit has extra shims for the job. I don't remember off the top of my head, but I added in a few more shims myself. As for the pinion being waaay out. Make sure you have the center pulley on the right way. The screw heads holding on the spur should be facing the motor.
#1360
There should be a little play in the center pulley to cushion some of the torque as well as keep the drivetrain free...this is normal in most Belt Kit car. My 416 Drivetrive spin like my Shaft kit........which is a good thing. I did shim very little myself. Once there is pressure on the spur gear it will stay in place (centered)until you let off on the trigger, but if set correctly the pulleys should not come in contact with anything, with shims or with out. I use Tamiya pinion gears they will stay in contact with th face of the spur gear.
Jmac I forgot to change the setting on my radio Timeframe on the servo to the 5.5 from 11.? This make a huge different in the the straight line performance.......Now the kit is starting to hold down like my RAY08......She is ready! This is why the car was so hard to drive....I was fighting the servo center adjustment.
#1361
NSX body in GT2 on my TA05R (qual'd 5th overall)
SC430 body in GT1 on my 415 MRE (qual'd 10th overall).
I didnt get a chance to try the NSX on the GT1 car, but would have liked to. The TA05R was a joy to drive, while the 415 was a handful. Laptime wise, the GT2 cars were only a couple tenth's slower than the GT1 cars.
Oh, let me now when that 416 goes on the auction Block . I'd like to try one for the Memphis race
Jimmy
#1362
You sure it wasn't the new tires you put on your Ray that made it better? I was fighting my car down the straight. My servo saver doesn't center. I need to either put back on the old one. Or mod my aluminum one. I keep trying to order the right aluminum one from HK. But they are always out of stock. So I may try to first whip out the file and see if I can get it to work properly.
Anyways, bring the ray out next weekend to Fayetteville. I wanna see what it's got.
Does Todd read this?? A few days ago I emailed him 2 times but the emails bounced back. I don't know if he got my replies or not. I sent him a reply through RCTech. So I dunno if he got my response on the toe blocks. He needs to check his email address he has listed.
#1363
I'm using a S9950 btw
HiH
Ed
#1364
I used to only run servo horns. I love the way the car feels that way. But some tracks I need to run servo savers. Some of the small tracks I run on have large PVC elbows/pipes that stick out for corners. Not good for my servo if I cut too tight or get knocked into it. I've already replaced all the gears in my servo. I run the s9550. You would think it's the 1 plastic gear that strips. But actually sometimes its the brass gears. That costs $40 for the kit. I have plenty of plastic gear spares though. Also I've learned that if the crash is hard enough to strip the servo gears, it's hard enough to bend the steering linkage arms. I dreaded that with my EvoIV. I don't know how many times I've had to replace the steering linkage arms in that thing from running no servo saver. I do however only run a servo horn if the track has curbs or corner dots for corners.
