Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 01-30-2008, 05:00 PM
  #1201
MACHFIVE is offline
Old 02-01-2008, 12:36 AM
  #1202
Default gear ratio and spur
Hi,
Just a little question.
The stock spur is 64dp?
What end gear ratio should I have with a 19t (orion element V2) on a rather small technical track?
Thanks!!
delanobe is offline
Old 02-01-2008, 02:13 AM
  #1203
I saw that Jilles, Viktor and Marc used D/D and XA/E blocs. Is it blocs from the 415, 416 or EVO5???
Also do you have the part number for the servo saver they used??? It's a black and alu blue one...
Where can I find these parts.
Hugo is offline
Old 02-01-2008, 02:35 AM
  #1204
All the blocks that are not included in the kit are 415 ones. The servosaver is from square, http://www.racingfactory.fi/shop2/ca...ils.php?p=1759
Mr_Orange is offline
Old 02-01-2008, 05:23 AM
  #1205
Default Shocks
Hey guys
I just need a little help with my TRF tamiya shocks.
I just need to know how to set the rebound ?
I did have an xray and they have a hole in the top of the shock to bleed some oil out.
The tamiya has nothing, any help would be appreciated.
thanks!!
ghost rider is offline
Old 02-01-2008, 08:17 AM
  #1206
Originally Posted by Mr_Orange
Shock rebound is the amount that the shock shaft rebounds back when fully pushed in. The percent is of the full travel of the shock. An example of how it is set: lets say you want 25% rebound, push the shaft in 75% without the bladder attached and then put on the bladder and screw on the cap. Now you should have 25% of rebound.
Hope this explains it.
This is the way i´ve been tought by the pros.
Old 02-01-2008, 03:15 PM
  #1207
Stein Tumert's Avatar
Originally Posted by delanobe
Hi,
Thanks!!
According to my knowledge, not 64dp, but called "modul 0.4" which is very close to dp64, but not 100% the same.
See http://www.rc-blitz.ch/advanced_sear...ords=modul+0.4
Stein Tumert is offline
Old 02-01-2008, 03:36 PM
  #1208
Just to be clear. Although it is technically .04, you can use 64p pinion gears with no issues.
DOTMAN is offline
Old 02-01-2008, 09:23 PM
  #1209
Moderator
pc9840's Avatar
Default My 416
I have my 416 coming in next week. What are some spares that I want to stock up on? And do I need to add anything to the car out of the box? Suggestions are very welcome...
pc9840 is offline
Old 02-02-2008, 01:02 AM
  #1210
Correct, 04 module translates to 63.5 pitch which meshes ok with 64 pitch.
Old 02-02-2008, 07:26 AM
  #1211
Right, I have also used that combination without problems, but it is also easy to put on a 64dp spur
Old 02-02-2008, 07:32 AM
  #1212
Trader Rating: 51 (100%+)
Originally Posted by JimmyMac
I have raced at 3 different carpet track with rubber tire. I don't find everything getting gummy. But I do find a chunk of black fuzz or gum stuck in one of the pulley teeth from time to time. Is your car riding too low? What traction compound are you using?
I used Paragon and the car was never lower than 5mm at anytime during the weekend.
Apex is offline
Old 02-02-2008, 09:03 AM
  #1213
Questions??
I copied the set up from Jilles and the car doesn't feel as good as it should. SO now here is the question regarding the hop up arms (short reversible arms 53928).
If I understand correctly D1 is for the front and D2 for the rear?
On the arms you can see a little stamp(inscription) D1 + D2.
Should this stamp be on the bottom or top? Maybe this is why the car doesn't feel wright?
Thanks for the help!
delanobe is offline
Old 02-02-2008, 12:52 PM
  #1214
Default 416 JAAD spool
seen this ?
http://www.racingfactory.fi/shop2/ca...ils.php?p=1765
Andyg01 is offline
Old 02-02-2008, 02:37 PM
  #1215
Listen up 416 owners - or posibly buyer's
You have 2 choises when you get a 416 kit.. you make af BIG stock of 44mm driveshafts, and c-hubs, OR - you do as i've done. Replacing the front suspensions with 415 msx suspensions (46 mm etc.)
Belive me.. the 44mm alu driveshaft's just broke if you have a little crash with another car (or curb : )
It might understeer a little, than if you had 44 mm driveshafts, but if you set 0.5 higher camper at the rear, than the front it isn't any problem. Since i changed to 46mm in front, i haven't brok ANY driveshaft at all..
But in my opinion it's the most high tech car i ever owned and drowen.. it realy can't be compared with the 415, and msx's..
As we say in denmark.. "Tamiya - keend den på knækket "
pp-racing is offline
