Top electric Lipo Charger?
rc power 601bc
1 to 4 lipo
1 to 14 nicad and nimh
1 to 12 volt pb
also with balancer youcan look at each cell (lipo only)
also BC5
samw as rc power just need the right plug for your packs
rc power only thru ebay driect from maker around 100.00 bucks
bc5 most hobby stores
check out your LHS look in the heli and airplane side as they use more lipo the car guys
1 to 4 lipo
1 to 12 volt pb
also BC5
I like my Scorpion from FMA.
#20
Bantam BC5 is a good compact charger. I went out on a limb with one of these and have only had it for a couple of weeks. Seems to be performing very well so far. They can be found around $125 with balancer built in - eg http://shopping.rcmodel.hk/product_i...oducts_id=9559. Note mine did not include all the different harnesses, just one harness with the charger plugs on one end and bare ends the other.
#21
This is the one I have been looking at
http://cgi.ebay.com/BNIB-Swallow-2-A...QQcmdZViewItem
I wish I could find it with a US a/c plug.
#23
For car use 2S lipo...(orion 4800/3200).......I like the FMA Scorpion ($90). Back on the track in 20 minutes safely!
http://www.fmadirect.com/Products.htm?cat=32&nid=24
#25
(1) Hyperion 1210i charger http://www.maxamps.com/EOS1210i.htm
(2) LBA6S Balencers http://www.maxamps.com/LBA10.htm
I have the Hyperion 1210i and the LBA6S balencers andit is great. The charger will charge at 2s and it gives you all the info you will ever need on your pack that is charging. You can also hook up (2) balencers to 1 charger and charge 2 packs (identical packs) at once. Almost like having 2 chargers, nice. The menus are easy and it will charge and discharge nimh too.
#26
Competition Electronics Turbo 35 GFX LiPo Ready
Checkpoint TC1030
LRP Pulsar 3
Duratrax Ice
Depending on your budget I feel threse are the 4 best chargers on the market
I always use an external cell balancer. Either the Thunder Power or AstroFlight Blinky!
Checkpoint TC1030
LRP Pulsar 3
Duratrax Ice
#27
Here is their site: http://www.bantam.co.kr/
Look at the chargers on that site and compare them to a few others more commonly seen.
#28
OFNA charger.
#30
No one has mentioned the e-station bantam bc8 either. It is pricey but it will charge all your lithium cells, nimh, pb, and balance too.
If all you are going to charge is 2S lipo, I'd say go for the Scorpion 2S. It is cheap, only $70 from FMA direct and charges at 10A.
