Top electric Lipo Charger? >
Old 08-20-2007, 12:31 PM
spurgear's Avatar
Default Top electric Lipo Charger?
What would you say is the top battery charger for Lipos today? It was recommended to me the Duratrax ICE is the best?
spurgear is offline
Old 08-20-2007, 12:53 PM
Trader Rating: 38 (100%+)
The duratrax ICE isn't the best, but definitely the most versatile for its price. For the ICE to be the best, it would need balancing capabilities. If you want lipos, you need a way to balance them. You can buy the ICE and buy an add on balancer like the Hyperion LBA6S like I use.
The best lipo charger for a good price is probably the balancepro hd from FMA direct. It can charge up to 5S lipos and A123 lipos at 10A, and it balances for just over $100. The only problem though is that this charger does not charge nimh batteries or nicds. I have been doing a lot of research on lipo chargers lately, and if anyone can find a better lipo charger than that, post it!
mattnin is offline
Old 08-20-2007, 02:28 PM
I mentioned it elsewhere, but the Team Checkpoint TC1030P charger does Lipo, NiMH, NiCD at 10amps (20amps discharge, although none needed for lipo). It slso does motor check & break in and can run a lathe
On the downside, it doesn't balance though, so you'd need to look out for one of those.
chris_dono is offline
Old 08-20-2007, 02:31 PM
Thunder Power TPS-1010C, used with the thunder power balancer. This charger has a port that can "talk" to the balancer, so you can view the data for each cell.
It's expensive, and the instructions suck, but it's the best LiPo charger out there.
And stay away from chargers that will do lipo and nimh. It only takes once charging a lipo in nimh mode to ruin your day.
jiml is offline
Old 08-20-2007, 04:49 PM
PeteB's Avatar
the supernova competition is a great charger, does nicad, nimh, LIPO,lead acid and a few others, has a temp sensor safety cut off, senses the type of battery so you cant F*ck it up (eg charging a lipo on nimh mode), wont let you charge a lipo at more than 1C, unless you manually override it. dischages at upto 20amps
PeteB is offline
Old 08-20-2007, 05:34 PM
wallyedmonds's Avatar
orion
wallyedmonds is offline
Old 08-20-2007, 06:08 PM
adamge's Avatar
The Ice is barely a lipo charger. It has the option to do it, but that's about it. The best lipo charger is the Thunder Power 1010C.
adamge is offline
Old 08-20-2007, 06:11 PM
Team EAM
Trader Rating: 79 (100%+)
The recently released Pulsar 3 is a great all around charger too. It does nimh, lipo, discharges, breaks motors in up to 20 amps, etc....all for around 150.00.
EA
EAMotorsports is offline
Old 08-20-2007, 06:55 PM
The thunder power is hardly the best lipo charger, it doesn't even include a balancer and for $200? That is a really high price not to include LI-FEPO4 support (A123).
mattnin is offline
Old 08-20-2007, 07:01 PM
Trader Rating: 19 (100%+)
i got a thunder power charger... the TP-535. is it essentially just a baby sibling to the 1010C? is it any good?
i haven't been able to use it yet, but i'm hoping it does alright for $80
Mallanaga is offline
Old 08-20-2007, 08:55 PM
adamge's Avatar
The way the charger is marketed and sold doesn't affect how good it is at charging lipos.
The 1010C does indeed charge A123, NiMh, NiCD, Pb, and lipo.
Introduced two years ago at $200, it was a steal that revolutionized the lipo charging market. Now there are a few chargers that equal it in the power per dollar range, but none are superior.
Mallanaga, the 535 is definitely nice. I often use it instead of the 1010C that sits beside it because of the ease of use and small size. At $80 you got the TP power supply with it, right? That's definitely a sweet combo.
adamge is offline
Old 08-20-2007, 11:51 PM
yeah. power supply to boot. that's what i was looking for. all these chargers, but most require an external power supply. same goes for the 535, but at least there's an option for a small size, easy AC solution.
good to hear that i have a quality product here. when i do get around to using it, i'll definitely have that piece of mind.
also... do i really need the balancer to go with it? signs point to yes... but i don't want to spend the $50 if i don't have to. yeah, i'm cheap. lol. i have 1-2S, and 2-3S batteries. all thunder power. how often should they be balanced?
Old 08-21-2007, 05:39 AM
Alltapdout's Avatar
Has anyone tried the Integy INDI lithium charger?
Just wondered?
Alltapdout is offline
Old 08-21-2007, 05:51 AM
MrUnlimited's Avatar
According to your signature your a gasracer so I assume you want to charge your receiver batteries (lipo) Why such a high end charger which is meant for electric racers?
Here is a solution for you at a reasonable price. http://cgi.ebay.nl/Bantam-e-station-...QQcmdZViewItem
MrUnlimited is offline
Old 08-21-2007, 06:17 AM
QuickRC's Avatar
Just wondered?
I use an Integy 16x8v6 and it is great for everything except LiPos. It will charge LiPos but false peaks a lot. You have to restart a few times through the process... The ICE works very well with LiPos and is a better all around charger but of course has less functionality in a lot of areas.
QuickRC is offline
