Kyosho VoneR Thread
#1201
Originally posted by HEYALIGNMENTGUY
Went to Delta to race today but had a few things happen to me that I have never had encounterd to day the body flying off in the main but that is an easy fix but here is one I have never had TRACTION ROLL more or less when I enterd the schicane on power the car would flip but if I rolled into it and powerd out it was OK but lost lots of time when the car was on its lid
I was useing the kawahara foams 40 in front 35 in rear stock spring in front silver in rear black sway bar in front and silver in rear. any help would be appreciated
As for camber link. use lower/inner and upper/hub. 55 or 60WT shock oil.
Hope this help
#1202
Originally posted by Manticore
You have your suspension too soft and you should have harder shore in the rear. try 42/42 F/R. gold springs all around. If you are using the new front sway bar, set it to softest positon and use gold in the rear.
Hope this help
I will try that I have 60 wt in the shocks at the moment, I would have never thought that the car was too soft, Intersesting.
THANKS
Has W FOK knocked on your door, he is lurking around HK this week just look out for I guy who calls himself
Hope this help
THANKS
#1203
#1204
HAG
Your setup is fine dude.. But do check your ride height. I have a feeling that your car is up there. Try lowering ride height to about 3.5mm to 4mm. For the 15 min main, I ran 4mm F and R. Try that first before anything else.
#1205
Originally posted by Jonathan
HAG
HAG
#1206
Regional Moderator
Lola body is soooooooooooooo good! It is ten times better than Stratus.
#1207
#1208
Regional Moderator
what makes you so excited? we all know this long times ago Mr. Moderator !
If you keep running Lola all the time, you can't get this excitment.
#1209
Originally posted by Ah10
Did you damage the KO 2143? if yes I am very sorry to hear that!
No it was not that it was the stock servo that came with the 3PJS....I think the KO2143 would have survived it....
#1210
got_speed?
Sorry .....to hear your mishap. I was there around 1PM with KevinK. I'm planning to go there next Sunday ...this time to race with Kevin and the other guys. If we have a good turn up , we can ask Karlton to run our class. Get yourself a GTP body.
It was a blast yesterday!!!
KevinK:
See you next week,dude!!!
KevinK:
#1211
Originally posted by TambokGT
got_speed?
KevinK:
got_speed?
KevinK:
#1212
I bought one ever since it first came in his shop.
#1213
#1214
He didn't race his V1R....he was racing his Mugen MRX3 with an EVO4 engine.
#1215
