Pipe Questions
the jammin pipes will fit most all 1/8 buggies, truggies and alot of MT's...
the JP1 is a low end torque pipe like the 053 and the JP2 is a high end torque pipe like the 086, and the JP3 (what i use) combines the best parts of both the JP1 and JP2 having great power through the entire power band....
Keep in mind that the terms "low end pipe" and "high end pipe" are relative. A JP1 is known and marketed as a low end pipe but on an RB or Picco engine they have screaming top end. The pipe and engine are just a good match. Be sure to ask around about which pipes match which engines. You may find that there are exceptions to the rule.
I'm reading exactly what I thought...but wanted to air it for discussion.
I have the JP2 and the 086...going to test them on my LST2. Keeping in mind the LST2 does not use a standard header like a buggy or truggy.
I thought about buying the 053 and 063...but I like the anodized Jammin pipes as they can take more abuse.
dynamite makes their hard-coated version of the 053 and 086 for under 50 bux with header. I ended up buying both for my B01A.
