3pdf and xxtra question
will the 3PDF TX work with novak xxtra? it notes that the rx is only compatible with PPM Modulation.. what do you think about 3PDF? do you think its PPM?
Please note: (from novak) the XXtra is only compatible with transmitters that use PPM Modulation.
up up up
I know it works with the hitec lynx 3d radio and spectra module.. Hitec radios are only FM.. They are also negative shift and are compatible with futaba.. I would say it will work..
