engine life?
Old 01-13-2007, 09:17 AM
t-ray's Avatar
Default engine life?
how long does the average big block nitro engine last?
t-ray is offline
Old 01-13-2007, 11:06 AM
Depends on what you do with it and how abusive you are. They can last from a few minutes to several gallons of fuel. On the average, about 5 to 6 gallons.
AreCee is offline
Old 01-13-2007, 03:37 PM
t-ray's Avatar
thanx
t-ray is offline
Old 01-14-2007, 08:40 AM
t-ray's Avatar
once your engine life runs out do you have to replace the whole engine or just replace it? (used to car engines where you just rebuild)
t-ray is offline
Old 01-14-2007, 08:44 AM
Nitroaddicts's Avatar
you can just do a piston sleeve rebuild. very easy.
Nitroaddicts is offline
Old 01-15-2007, 08:27 AM
RBMike's Avatar
If you tune your motor correctly and keep it clean (outside & inside), they can last much longer. It is more likley you will wear out the rod or a bearing before a piston & sleeve. It also depends on the quality of engine (& fuel) you start with. I have many old RB's and I have only bought 1 piston/sleeve set ever (lost aircleaner). I have bought a few rods & more front bearings than anything else. I run my cars at least 3 out of 4 weekends year round and have WAY more than 10 gallons thru each of the 4 motors I currently run (all RB's). My newest motor is more than 2 years old.
RBMike is offline
Old 01-15-2007, 11:05 AM
t-ray's Avatar
ok i just didnt know. i didnt want to have to buy a new motor every season
t-ray is offline
Old 01-17-2007, 06:08 PM
if you are on a budget, when the piston and sleeve wears out you can get them pinched and you should be able to get another 3 gallons out of them and it only cost $20.
davo798 is offline
Old 01-20-2007, 03:26 PM
hi rbmike i like how much pride and care you have for your engines im currently trying to decide on a brand that i can commit to and you have me favoring the rb concepts i`ve got a hyper mach 21 and a ninja bo1 (broken crank)and lately a os v-spec whitch rb do you prefer ws7 3 or c6bb for short to medium technical tracks her in queensland also what pipe and fuel do you reccomend
pitdog is offline
Old 01-20-2007, 04:44 PM
t-ray's Avatar
how many times can i get them pinched??
t-ray is offline
