Gm Brushless Systems
#31
make sure the + and - wires from all 3 caps are soldered directly to the + and - posts.
you will get stuttering problems if you attach the caps to each other and only have 1 wire going to each post or if you extend the caps away from the esc with wire.
it is something the gm esc seems to be very sensitive to.
#34
Originally Posted by Holmenkollen
I have the exact same problem and I canīt get into setup mode either. This is my 2nd GM speedo, the first one was exchanged.
I have the same problem , i can't get into set up mode too , it's not button's fault as i've checked it , is not anything about caps or witring cause i changed them and wired them in an other way , and this is my second GM too!!!
Can anyone help with the set up problem??? could this be a motor's fault??
#35
#36
Most likely itīs something with the motor. Unscrew the endbell and check the solderjoints. On my motor one of the solderjoints had lost contact with the circuitbord.
and you couldn't set up??? After that you can set it up correctly???
#37
#38
Can you tell me how???
I mean about the wires , which-where??
And i am asking again to be sure , if i connect a brushed and i can set up is somenthing wrong with the motor , if no is something wrong with the speedo, right???
#39
Check the manual, it shows clearly how to connect.
#40
Unfortunately i don't have one , but i will try to download it...
#41
How does the GM Genuis 95 compare to the LRP Sphere Competition 2007? I am not going to run a low turn motor maybe a 7.5 brushless at the most - but will use a 13.5 BL for stock to start with, for both on-road and off-road use.
Cheers,
Tony
Cheers,
Tony
#42
then you can also take a genius 80 or 85. much cheaper and also good.
#43
Ok thanks
#44
a question: what does the "armature" setting do in the software setup program for the genius95 ?
Thanks!
Thanks!
#45
If anyone is looking for a genius 95 I'm selling mine as I bought it for my touring car but I've decided to sell all my TC stuff so I have one Only ran for about 30 seconds. Willing to make a grat deal including 2 GM motors (4.5 turns) PM me if your interested.
Sold thanks Tony
Sold thanks Tony
