Engine prob....
Engine prob....
hi guys....now i got a headache...
i have already run-in my engine already. but when i go full throttle and brake....the engine stall? the throttle trim on my controller when i set to low side...the engine stall too. Even without full throttle, just hit on the brake...it will stall too.
what could be happening??
PS: if i have put a little more then few(actually quite alot...accidently) drops of nitro to the carb before starting the engine....will that cause this prob?? if yes then how to retified
hmmmmmmm now where can we start ........
maybe it would help to give some details of the motor and rc car which will be a good starting point...
Could be clutch set up or engine tuning
With the engine off, remove the air filter and look inside the carb. Apply the throttle, then the brake. Make sure the brake isn't completely closing off the carb. If it is, adjust your brake trim.
Just my 2 cents
Just my 2 cents
ya when ur throttle is fully close there shld hav the slightest gap. check ur engine manual it shld indicate the setting. it shld look something like this (for O.S. engine tz5p)
