Yokomo MR-4TC SD
#5416
Originally posted by kt tracing
You say you need more traction. Is that on the whole car or on the front or rear specific?
#5418
My first experiences Indoor:
1. Broke Tobee Dogbones in the front, changed to original steel
2. Broke 3 (!) Steel dogbones in the front left, then right, then left.
3. Broke Steering hub & Carrier front
4. Broke Lower Suspension Arm front
On outdoor no problems, but Indoor just shocked me! Have anyone had the same experiences? Any solutions?
Which dogbones will last longer? I saw that yokomo worked on the design of their steeldogbones, but i think the material is a way too soft and the design isn't perfect.
Which MIP would fit? Article No? Will graphite parts last longer?
Thanks for any sugestions!
#5419
try Square Ti bones in the front...+graphite suspension parts wich for the SD are actually stronger than the stock ones (this is not a myth!)
nice signature Mr Patriiick!
#5420
Originally posted by vtl1180ny
Sorry... Indoor, ozite carpet... I'm still using the stock 70 tooth gear...
#5421
That indeed is shocking, but I must say I've had no problems with any dogbone I bought, being the steel, yoke aluminium or Tobee aluminium (oh yes, they tend to twist the aluminium from Tobee is just chewing gum, nothing really bad though).
And I run high grip carpet with hot 12T, and the track is so tight that you can't avoid crashing at least once a run. Never broke anything there !
#5422
Originally posted by Patriiick
maybe the CGM version will help, now that it is available in the UK
(private joke for Cobra.. )
#5423
Wow it still blows me away how many people report back with a bag full of broken parts.
ITs not the car its the driver 90% of the time. The SD is no different then the TC3 or the Xray with c-hubs. If your fastest laps consist of riding the boards 2-3 times a lap your gonna break. But lets assume thats not the case. Im not pro driver i dont ride the boards but hey i have smaked the walls through s-turns and other tricky areas.
I will make a prediction that the guys breaking parts are running the stock bumper with no extra support.
Since i installed this i have run well over 20 race days without breakage. I have a total of 4 broken parts before the bumper was installed and about 2 since then. None of my broken parts happened while racing just while goofin around practicing. I run on tight carpet track with rubber and foam on 2 SD cars.
I sound like a broken record but here is the buds bumper installed on my SD
Everyone should have one
#5424
There's nothing exceptional about mine, but I have made some minor alterations that seem to help. For starters, the CVD's have to be machined out ever so slightly where the 'barrel' goes through joint and then polished. Otherwise they friction weld themselves together and seize. The pins don't hold in too well either because they are polished and the grub screw cant grab them. I use a narrow band of battery wire heat-shrink to hold them in place in addition to the grub screws. This works really well
I use Team Suzuki Alloy Steering arms/hub carriers all round. I have just started useing the new SD008G arms and although they seem better, I haven't crashed with them yet so I cannot say that they are more durable. Others are saying that they are far stronger though, which is good news.
#5425
Héhé, one more from switzerland
In how many runs ?
Oh btw, Cobra, thanks for your article(s) on overrc, it made me buy the car, instead of the Pro4 (especially regarding the access to some pieces like diffs and spur gear)
In how many runs ?
#5426
Joel:
Your bumper modification looks really good and should help those who have alot of front end/heavy crashes.
What I have witnessed REPEATEDLY is SD's breaking where just the most minor clipping of corner dots or boards has resulted in one corner (or in some cases BOTH Corners ) parting company from the car. I have also witnessed C-Carriers splitting at the bottom FOR NO APPARENT REASON, during the race but without actually breaking off. This obviously trashes the handling of the car and the culprit is normally a seized front driveshaft.
There's no way anyone is going to tell me that the SD is as durable as a TC3. Cos It aint. I have both cars. I know plenty of club racers who can get a TC3 through many meetings without bits breaking. I got mine through 2 seasons WITHOUT BREAKAGE!This unfortunately is not the case with the Yok SD which (in my mind) is still under development. All the drivers I saw break their SD's at the last meeting were experienced Pro drivers - National winning drivers in some cases! The materials used for the plastic components need to be revised - period. Lets get this sorted, otherwise they'll be no UK drivers for the SD.
#5427
Horatio,
I agree with you completely! I recently purchased a Yok SD and the very first time I raced it I clipped a corner with the rear of the car and shattered the a-arm. Not a hard hit at all. What was worse is the dogbone seized up and I had to beat, tap that is, out the barrel with a allen driver. My day was shot because the track didn't carry dogbones for the SD. Had to pull out my Xray and continued on without a problem. And, I did hit the wall harder with the Xray a couple of times negotiating traffic than I did with the SD and not a failure. I also raced my Losi all last year indoors and two months this year without a broken part.
For the limited amount of time I had driving the car though I was impressed with the handling and acceleration. Once I decide how to fix the dogbone problem I'll continue to race it.
#5428
Thank you guy for the responses. I'll try out the grphite parts, for sure. I wonder, if there's no CVD from MIP which would fit?
The Square parts are far too expensive, due it's titanium.
I remarked, that the first steel dogbone had a small turned groove, where it always broke. I just touched the barrier quiet softly, during a manouevre, and off it was! That's not very promising. Even the Alloy MIP from my PRO2 wouldn't have broken with that little incident.
I'm really disappointed. I almost broke every 2 pack a dogbone, and I'm not such a bad driver, but with almost every touch of a barrier something broke. It remembers me the first time I drove the PRO3 when it was new...
Switzerland rulez!
Switzerland rulez!
#5429
Originally posted by daniz24
Hey, don't race with it !!! (The car with cool shock towers)
First thing first... better put your rear drive shaft to it's place LOL
All 4 driveshafts was out there coz i rebuilt the diffs before i took the pic and forgot them
Shortygy >> Sorry for the confusing text My car is off the tweaks for straight launches.. Checked on other boards too..
I started to paint m new body today (Nissan G350GT) and the masking i use sux! EVERY mask has bled and it looks like crap kinda cool tho with a torn-like look
#5430
